Adjusting PAC SIN-35
Old May 7, 2013 | 06:26 PM
The Q's Avatar
The Q
Default Adjusting PAC SIN-35
Installed a a pair of PAC SIN-35's to run instead of high level inputs into my SoundStream 4.520D amp. The SIN-35's came adjusted at the max setting. I tried that setting but it seemed to introduce distortion at an earlier volume level I have them set to the half way mark now and things seem good, but I'm wondering if they should be set lower. Any advice would be greatly appreciated.
Old May 7, 2013 | 06:55 PM
UltraNutZ's Avatar
UltraNutZ
I usually set them to either 1/2 or 3/4 depending on the system. On these bikes, I find 1/2 is more than adequate. Then adjust your amp gains from there.
Old May 7, 2013 | 07:08 PM
The Q's Avatar
The Q
Ok, I'm at half and then I set my gains again using the DMM method. I want to make sure I'm doing what I can with my sound system to get the most out of it. I realize most will then say replace the stock head unit, I'm just not ready to do that just yet. Thanks for the quick response!
Old May 8, 2013 | 06:38 AM
UltraNutZ's Avatar
UltraNutZ
no reason other than features and a bit of an increase in SQ to change the head unit out. It's perfectly fine for running these systems.
DougsGlide2018
Audio Systems
Jun 12, 2018 08:17 PM
GoatHD
Audio Systems
13
Aug 15, 2017 08:46 AM
Mirnldi@gmail.com
Audio Systems
Apr 10, 2016 07:03 PM
NorthEnd
Audio Systems
Mar 22, 2016 04:30 PM
jamess71
Audio Systems
16
Aug 21, 2014 09:07 PM
