Mounting speakers correctly?
Old May 13, 2013 | 07:23 PM
tdd77's Avatar
tdd77
Default Mounting speakers correctly?
Hello, I recently aquired an aftermarket fairing that had 6x9 cutouts and Polk db6x9 speakers. The mounting instructions were not much help for my application.
What I did was drill pilot holes in the fiberglass and used the screws that came with the speakers and screwed them right into the fiberglass and they seem pretty stout. I'm kind of nervous that over time the screws may work themselves out or worse yet damage the fiberglass.
Should I drill bigger holes and use small bolts,nuts and washers,or am I just being a big worrywart?
Thanks.
Old May 13, 2013 | 07:50 PM
sl33py's Avatar
sl33py
the way these bikes can vibrate, i'd do that with a dab of blue or even red loctite... Can't hurt unless you are going to replace components frequently.
GL!
Old May 14, 2013 | 07:16 AM
wils5150's Avatar
wils5150
the speakers in my aftermarket fairing had nuts and bolt
Old May 15, 2013 | 10:46 AM
UltraNutZ's Avatar
UltraNutZ
another thing you can use and they work just as well as bolts and nuts is speed clips. They should have come with your speakers with the screws. Simply slide a clip onto your fairing for each hole, then run your screws that came with the speakers through it.
This is what it looks like.
twincaman
2014-2024 Touring Models
Sep 29, 2015 09:34 PM
Bullitt59
Feb 8, 2013 03:07 PM
Str33tgl1de
Jun 7, 2012 06:54 PM
MrCarver
May 11, 2011 10:10 PM
Grunt66
Sep 1, 2009 04:41 PM
