Speakers in batwing
Old May 9, 2011 | 08:08 PM
MrCarver's Avatar
MrCarver
Default Speakers in batwing
How hard? How easy to install?
Old May 9, 2011 | 08:29 PM
RLJ676's Avatar
RLJ676
Are you talking replacing stock ones?
Easy, I just did it and it took 30 minutes. I used the adapters for 6.5's, if going w/ 5.25's even less time.
Old May 9, 2011 | 08:37 PM
ChristoHD's Avatar
ChristoHD
The hardest part, is removing the fairing - I say this with some tongue-n-cheek. If you can get the fairing off, the rest is easy. Unplug the +/- wires, unscrew some screws, the speakers pull straight out. I did it, as RLJ said, from start to finish about 30 mins.
Just watch when you unbolt the speakers, there is a bracket attached to one of the bolts/screws and look how the speaker spacer is oriented.
Old May 9, 2011 | 08:38 PM
buggy's Avatar
buggy
30 MIN OR SO. i HAVE THE HARLEY BOOM AUDIO,WAY BETTER THAN HOGTUNES.
Old May 9, 2011 | 10:26 PM
SDVmnt's Avatar
SDVmnt
Also be very aware that the screws are not all the same length. Put one of the long ones in the top and you're going to be really pissed. Don't ask how I know.
Old May 9, 2011 | 10:50 PM
iwillfixthem4u's Avatar
iwillfixthem4u
same and love them +1 on 30 min
Old May 10, 2011 | 06:40 AM
HRLYSG's Avatar
HRLYSG
And... check your fairing support brackets while in there. Especially if it's an older model.
Old May 10, 2011 | 07:04 AM
ajohnston78's Avatar
ajohnston78
Gonna find out in a week or two gonna upgrade mine also may do kit with amp also
Old May 10, 2011 | 07:14 AM
MrCarver's Avatar
MrCarver
thanks guys, I appreciate it. I was looking at it, looks like the headlight ring, and 7 screws for the outer fairing.. Didnt think it would be all that bad. Support brackets SHOULD be good, 2011 here Thanks again!
Old May 10, 2011 | 07:50 AM
imrotton2's Avatar
imrotton2
you dont hafta pull the headlight ring... you just unplug wires at the back of the lamp , when the faring is almost off
