Audio System Upgrade
Old May 14, 2013 | 09:32 AM
Molarman's Avatar
Molarman
Default Audio System Upgrade
It would sound great. If you want to keep your handle bar controls you will also need a kit from biketronics or hawgwired.
Old May 14, 2013 | 09:53 AM
zxport123's Avatar
zxport123
Audio opinions needed!
1. Alpine CDE-143BT radio
2. Rockford PBR 300 x 2
3. Polk mm651 speakers.
Equipment to be installed in 2002 Electra Glide Classic front speaker set up only.
Old May 14, 2013 | 10:19 AM
UltraNutZ's Avatar
UltraNutZ
good choices. You'll need a handlebar control kit as well from either Biketronics or Hawg-Wired
Old May 14, 2013 | 10:35 AM
lgenf's Avatar
lgenf
will sound really great compared with stock and probably sound great for a 2 speaker system
those speakers are top performers and you cannot go wrong with adding an amp
the fact that you are also changing the head unit, the sound quality will improve as well
Old May 14, 2013 | 10:40 AM
Blind1's Avatar
Blind1
Are saying the standard handlebar controls will not work? Reasoning? I've been thinking about upgrading as well...
Old May 14, 2013 | 11:36 AM
UltraNutZ's Avatar
UltraNutZ
the handlebar controls need to have something to connect them to an aftermarket head unit. Those devices can be found from either Biketronics, Hawg-Wired, Eastern PC Performance, DragonFly, etc.
But yes if you change the stock head unit out, you'll need a device to allow you to keep your handlebar controls.
Old May 14, 2013 | 03:36 PM
zxport123's Avatar
zxport123
Default Audi Sytems Upgrade
Thanks everyone for your advice
medicmike
Audio Systems
Jul 31, 2017 06:00 PM
sbeast
Feb 20, 2016 07:16 AM
sgriffin
Jul 21, 2014 09:14 PM
kryingame
Audio Systems
Mar 31, 2013 12:59 AM
hougz79
Sep 17, 2011 07:33 AM
