Help ultra
Old May 14, 2013 | 02:57 PM
yank721's Avatar
yank721
Default Help ultra
Ok so the tweeters came with a bezel that mounts up perfectly to the gauge hole so I'm installing but won't have the amp till next week... I'm using the biktronics plug and play kit and I need to know hoe to hook up the cross overs. So the tweeters and speaker hook up to the cross over then the input side of the cross over which would go to the amp normally but since I'm not doing amp today do the factory speaker wires plug in there or do I need to get RCA cables right now to go from the input side of the cross over to the radio? Hope I didn't lose you there lol thanks
Old May 14, 2013 | 07:11 PM
UltraNutZ's Avatar
UltraNutZ
no sir on the RCA cables..
what you're going to do is obviously connect your speakers to the crossover per the instructions. Then on the input side of the crossover simply connect your existing speaker wires that are going to your stock speakers. If I'm not mistaken the kit comes with little jumpers that make it plug and play.
Old May 14, 2013 | 08:35 PM
yank721's Avatar
yank721
Ok I have installed everything but the amp and understand that I can't finish the install till I get my amp in! But when it does come in I just tape up my factory speaker wires correct? And then plug the crossover into the amp and amp into the head unit right?
Old May 14, 2013 | 08:37 PM
yank721's Avatar
yank721
Oh wait sorry I just reread your post. Are saying I can plug the factory speaker wires into the input side of the crossover and ill be good? Sorry I'm a tad bit slow lol
Old May 15, 2013 | 06:11 AM
UltraNutZ's Avatar
UltraNutZ
you are correct sir. then when your amp comes in, simply move the stock speaker wires from the crossover to the input on the amp. then the output of the amp will go to where you had the stock speaker wires connected on the crossover.
252SGS
Audio Systems
Mar 25, 2019 02:11 PM
FlaDresser
Sep 21, 2018 10:12 PM
Tn.Heritage
Audio Systems
Jun 28, 2015 09:00 PM
blackv03
Audio Systems
Mar 21, 2014 07:38 PM
oscarg
Audio Systems
May 12, 2013 10:23 AM
