Gotta Short????
Old May 24, 2013 | 01:44 PM
bcane98's Avatar
bcane98
Default Gotta Short????
My Setup: 2009 Ultra Classic
HK Deck
J&M 7.5 speakers up front
J&M speaker in the rear
PBR300x4 amp
So here is my symptoms:
- In the 2000-2100 rpm range the HK deck cuts out
-- Actually music through the speakers
-- I push the 3 way speaker switch to another position (2 or 3), the music is still playing and comes through the speakers again
-- Sometimes I have to push it to position 1 and then back to position 2 instead of just pushing between position 2 or 3
The amp power light is not on when the speakers cut out. If the amp over heated or shorted the light would be a different color.
I check the grounds, power wires, speaker wires, connections, and I just can't seem to find a visible short.
So I am looking for any ideas, and any issues y'all might have come across in your dealings with similar issues.
Thanks
Rick
Old May 24, 2013 | 03:03 PM
scotty3's Avatar
scotty3
Yes the same as mine and it is a crack in the radio's PCB that is causing the problem.
It will get worse and worse until it finally dies and you will need to send it to Iron Cross Audio http://www.ironcrossaudio.com/
Old May 24, 2013 | 03:45 PM
bcane98's Avatar
bcane98
Great... Thanks for the help. I wonder if it covered under the extended warranty.
Old May 24, 2013 | 04:16 PM
scotty3's Avatar
scotty3
If you have extended warranty then you might be in luck.............
Old May 24, 2013 | 04:40 PM
bcane98's Avatar
bcane98
xxx xxx xxx
Old May 26, 2013 | 09:34 PM
bcane98's Avatar
bcane98
I remembered reading something about a self diagnostic on the HD radios, found the post about it, and it said Diag B2017 FL SPEAKER OPEN. Gonna open the hood in the morning to check my wires again before I bring it in for warranty work.
Little Mike
Audio Systems
136
Mar 5, 2026 07:59 PM
dad311
Audio Systems
Jul 27, 2015 07:22 PM
SmittyFXDL
Audio Systems
11
Jan 14, 2015 10:27 AM
dafuzz89
Audio Systems
14
Mar 18, 2014 04:44 PM
kdfoster
Audio Systems
Oct 4, 2013 07:15 AM
