Soundstream PN2.350D
Old Jun 6, 2013 | 08:16 AM
  #41
barkingspud's Avatar
barkingspud
Would it fit in an Ultra fairing with the Hogtunes bracket?
Old Jun 6, 2013 | 08:22 AM
  #42
UltraNutZ's Avatar
UltraNutZ
if you don't have the Polk MM crossovers in there BIG maybe but I took the measurements from the HT plate, made my own, and no way it was going to fit...
Old Jun 6, 2013 | 08:36 AM
  #43
Braveheart1222's Avatar
Braveheart1222
Preciate the review UN...
Old Jun 6, 2013 | 08:58 AM
  #44
barkingspud
OK cool...Thanks...
Old Jun 6, 2013 | 04:43 PM
  #45
rbferg's Avatar
rbferg
10ga is perfectly fine. My ammeter shows (obviously with speakers disconnected) at full volume and gains turned wide open a current draw of 11 to 13 amps.. Well within the scope of any quality 10ga wire.
Thanks....I assume using the speaker-level inputs would be fine as well with stock HU?
Old Jun 6, 2013 | 04:44 PM
  #46
UltraNutZ's Avatar
UltraNutZ
you would be correct again sir...
Old Aug 25, 2013 | 11:40 AM
  #47
rcpilot_971's Avatar
rcpilot_971
where do you set the crossover on the SS 2.350 Im using it to run a pair of focal 6 1/2
Old Aug 25, 2013 | 01:35 PM
  #48
UltraNutZ's Avatar
UltraNutZ
i'd set it to HP and set the control to about 80
Old Aug 25, 2013 | 07:23 PM
  #49
rcpilot_971
should I leave the bass boost set to off
Old Aug 25, 2013 | 09:12 PM
  #50
bayboy75's Avatar
bayboy75
Ultra........ Have you had to do anything special to upgrade your charging system? The stock battery is enough?
