Soundstream PN2.350D
Old Aug 26, 2013 | 07:18 AM
  #51
UltraNutZ's Avatar
UltraNutZ
Originally Posted by bayboy75
Ultra........ Have you had to do anything special to upgrade your charging system? The stock battery is enough?
negative sir. I will use Class D amps wherever I can and when I can't I'll use the PBR amps. These amps draw very little current in comparison to their counterparts in the Class A/B/C ranges.
Never had a need to beef up a charging system in any way. Your battery is a whole different story though.. If you think you have a weak battery, regardless of whether you have a stereo system installed, replace it.
Old Aug 26, 2013 | 07:19 AM
  #52
UltraNutZ's Avatar
UltraNutZ
Originally Posted by rcpilot_971
should I leave the bass boost set to off
YES YES YES YES YES
do not fool with that bass boost control on a 6.5" speaker. Early grave for your speakers without a doubt.
Old Feb 17, 2015 | 07:11 PM
  #53
shall's Avatar
shall
Stage III
Ultra I have tried to down load your suggested wiring for the SS PN4.520D I understand there is a differents between the old and new wiring harness mine should be the new one. the link that I have found is broken could you send it to my email? thanks Steve
halls4ofus@live.com
Old Feb 18, 2015 | 07:36 AM
  #54
UltraNutZ's Avatar
UltraNutZ
halls4ofus@live.com
what bike?
what speakers?
The new amps don't have a harness with 8 speaker wire outputs on it. It's got 2 rows of screw down terminals on it.
AAWAV
Audio Systems
65
Oct 15, 2020 06:37 PM
Tailwind
Audio Systems
50
Apr 20, 2020 11:55 AM
ZX2BY2U
Audio Systems
Aug 26, 2019 08:04 AM
hypecat
Audio Systems
May 10, 2017 02:28 PM
Stang951
Audio Systems
13
Feb 18, 2015 02:25 PM
