Which Amp?
Old Jun 10, 2013 | 10:08 PM
badazzpred's Avatar
badazzpred
Default Which Amp?
Ok so I've decided Im going to move my BT Titan II's to my lower fairings and run a new set of BT7P1's in the upper fairing I plan to run them in parallel. I would like to know what amp would be the best choice? The 2 in question are the
Rockford Fosgate PBR300x2 or the
Soundstream PN2.350D
Also I see theres so much emphasis on the Polk audio MM651's So Im not opposed to running a set of these Instead as they seem to get rave reviews but would they work for this set-up?
Thanks
Old Jun 11, 2013 | 04:38 AM
GLACIERPEARL's Avatar
GLACIERPEARL
Why would you run them in parallel, .........or do you have rear speakers too ?? Do you have an amp now ??
What is your cuurent set-up ??
Old Jun 11, 2013 | 05:41 AM
badazzpred's Avatar
badazzpred
My current set-up is a Sony head unit, BT444 amp and a set of BT Titan ll's in the fairing. Everything is from biketronics. So to answer ur questions yes I have an amp already. No I do not have rear speakers nor do I ever plan on it. I was under the impression that running them in parallel would give me more power to each speaker.
Old Jun 11, 2013 | 07:01 AM
UltraNutZ's Avatar
UltraNutZ
you are correct with the parallel wiring statement but what GP is going for here is sound stage presence with the use of a 4 channel amp and your fader. This will allow you to fade to lowers a bit because once you get moving you're going to need that ability as you'll find that your lowers simply wash out.
Old Jun 12, 2013 | 09:39 AM
badazzpred's Avatar
badazzpred
So you guys are saying to go with a 4 channel versus a 2 channel is that correct? Also by going with a 4 channel vrs 2 channel will I be giving up more power to each speaker? because if all a 4 channel is going to do for me is allow fader control but yet give up power then I opt for a 2 channel once again. correct me if im wrong please.
Thanks
Old Jun 12, 2013 | 10:34 AM
UltraNutZ's Avatar
UltraNutZ
no what we're telling you is
  1. the SSPN2.350D is a more powerful amp than the PBR300x2
  2. you're better off using a 4 channel amp or (2) 2 channel amps to accomplish your goals.
  3. If you're looking for power and not concerned with anything else, go with 2 PN2.350D amps. that would give you 175x4
Old Jun 12, 2013 | 11:08 AM
badazzpred's Avatar
badazzpred
Man this audio stuff gets confusing at times! Is there a 4 channel amp out there that will do 175x4? Im not opposed to 2 PN2.350D amps but mounting both is the next problem? So if Im not concerned with anything else what would the power rating be X4 with only 1 PN2.350D running my four 4 ohm speakers in parallel?
Old Jun 12, 2013 | 12:36 PM
UltraNutZ's Avatar
UltraNutZ
if 4 identical speakers are used which brings the impedance load the amp sees to 2 ohms, the power would be split up evenly between all 4.
350/4 = 87.5w
you'd be better off with a PN4.520D which would be 100x4 @ 4 ohms. That's more than enough power to drive those speakers efficiently.
Old Jun 12, 2013 | 01:27 PM
badazzpred's Avatar
badazzpred
350/4 = 87.5w
Thanks UN, I listed the speakers I plan to use in my original post at this point unless theres better suggestions? I see what ya mean now power ratings wise amps/speakers/ohms/etc etc....but if I did go with the PN4.520D wouldnt that technically be 130X4 not 100x4 at 4ohms?
Old Jun 12, 2013 | 01:46 PM
UltraNutZ's Avatar
UltraNutZ
no sir.. the PN4.520D specs are as follows
14.4v @ 4 ohms - 100x4
14.4v @ 2 ohms - 130x4
