Need help getting wires into my hard bag
Old Jun 12, 2013 | 06:35 PM
Fire4Effect's Avatar
Fire4Effect
Originally Posted by GLACIERPEARL
I run 1200 watts with zero problems on an Ultra, so I think you'll be good there. Find out how big you need to drill your holes for wiring, ( as small as possible), then order some grommets online , for a tight, waterproof seal. I use Deutsch connectors on my saddlebags. Slotted the top of the bag, and added a rubber grommet.
Jegs has a cheap kit online that has an array of sizes.
Old Jul 25, 2013 | 09:51 PM
DocCaliGRNS's Avatar
DocCaliGRNS
what connector did you use for the 8 gauge power wire because i cant find a deutsch connector in 8 gauge
Old Jul 26, 2013 | 06:30 AM
UltraNutZ's Avatar
UltraNutZ
the deutsch connectors in his bags are not for 8ga wire. Without knowing for sure but knowing GP, the wires going into his bags for 2 speakers each bag are probably 12 or 16ga and 4 wires needed for each bag so it would be a 4 pin deutsch connector.
If you're looking for an 8ga connector to keep your bags removable you'll probably need something like this to keep it relatively small in size. Just make sure that your wire coming from the battery + lead is on the femal side of this connector.
Something to keep in mind also.. Most 8ga wire is not actually 8ga and will fit perfectly fine in a 10ga connector.
Old Oct 29, 2014 | 05:35 PM
sharkmotorcycleaudio's Avatar
Former Sponsor
Originally Posted by n2wbj1960
Thanks for the help,gents. I was planning to get a 600 w shark audio system.But thinking about it, now I'm wondering if the oem stator & regulator can take it(?) . My first step is trying to fish for some ideas on the best way to physically get the wires in & out of the hard bag. I guess I need to drill a hole through the side & somehow weather proof it, but I still need to be able to easily remove it. Any ideas? Thanks again!!
How did you make out with the shark?
Old Oct 30, 2014 | 08:39 AM
chunngle's Avatar
chunngle
Hey gang -
Just got an '09 road king & I am looking for advice on how tho get 12 V inside my hard bags for an amp, while still being able to remove them.
Thanks for your help.
These guys make quick connect harnesses:
http://americanhardbag.com
Old Oct 30, 2014 | 11:16 AM
jamess71's Avatar
jamess71
Wow that is one nice looking wiring harness. At first I thought the price was high, then I started thinking about how much work that would take to make. Nevermind sourcing all the different connectors. Of course I would still make my own. ;-)
jt metal
Audio Systems
Jul 29, 2019 08:31 PM
05sportie
Audio Systems
May 10, 2019 06:04 PM
odie-in-az
Mar 24, 2012 09:12 PM
Big Jake
Jan 24, 2011 08:29 PM
dredy2g
Mar 11, 2009 02:18 PM
