I might be able to get a good deal on an Alpine CDA-105 head unit. Question is what else would I need to install it in my batwing in place of stock radio, and to get it to use stock handlebar controls? Thanks for any help.
you will NOT be able to use stock speakers on that head unit as they are 2 ohm speakers and the alpine head unit is only good down to 4 ohms. If you add an amp into the mix then your speakers MUST match what the amp is stable at.
