Strange audio problem
Old Jun 25, 2013 | 11:59 PM
dynacop25's Avatar
dynacop25
Default Strange audio problem
Just purchased a 13 FLHTK... when I plug my iPhone or iPod nano into the aux jack I only get sound from the left speakers... this is my first bike with a fairing so I am not sure if this is normal or not... anyone else ever experience this?
Old Jun 26, 2013 | 05:33 AM
Pondskipper's Avatar
Pondskipper
If you are using the same lead for both then the lead is likely faulty, if different leads then it is an issue with the jack.
Old Jun 26, 2013 | 08:34 AM
MontyCop05's Avatar
MontyCop05
Probably a bad cable. Try a new, high quality one. If that isn't it then it could be the AUX input in the radio. If that turns out to be the case it a warranty repair.
Old Jun 26, 2013 | 08:36 AM
Molarman's Avatar
Molarman
Check your balance settings. I know it sounds obvious but I have done this. Also make sure plug is fully seated.
Old Jun 26, 2013 | 06:56 PM
dynacop25's Avatar
dynacop25
Changed out the cable for one from hog tunes... solved the problem. Thanks y'all for all the help!
dynacop25
Jun 26, 2013 09:19 PM
cave9269
Jun 19, 2012 07:23 AM
Mixter
Jan 18, 2012 09:49 AM
BezerkoBob
Audio Systems
Dec 27, 2011 11:54 AM
moondog99
Oct 5, 2011 09:29 AM
