New "diy" audio harnesses for baggers
Old Jun 28, 2013 | 04:43 PM
Dragonfly2000's Avatar
Dragonfly2000
Default New "diy" audio harnesses for baggers
Dragonfly Cycle Concepts has just launched our full line of plug and play audio harness kits. These kitsallow you to use whatever radio, amp, speaker combination you wish; while getting a true professionallooking install.
All of our kitscome with name brand, highquality, professional gradepower and speaker wires, wire connectors, fuse packs, RCA cords, and even linelevel converters (for OEM Radio applications). We have also made adding speakers even easier by creating quickdisconnect speaker wire harnesses for your lower fairing, saddle baglids, and Tour Pac speaker pods.
Combine these kits along our Aftermarket Radio Install kits we've had foryears and the origin conical shaped speaker adapter, and you have everythingneeded for a truly professional installed system whatever amp, radio, speakercombination.
Whether you are upgrading the system on your bike or have a shop, we have everything you need to do a professional motorcycle audio install; Complete Radio and Amp wiring harnesses measured and bundled, speaker adaptors, radio mounting, and our latest edition audio integration harness for Harley Davidson CVO models!
**Please note Dragonfly Speaker adapters havea chance of NOT working with Polk Audio Speakers, and don't work with HawgWired speakers that have the Tweeter mount on the front of the speaker mountingsurface.
Old Jun 28, 2013 | 04:51 PM
UltraNutZ's Avatar
UltraNutZ
very nice kits I must say.. Very well thought out with "top notch" craftsmanship. The line level adapters are a set 10:1 reduction adapter which is best for 99.9% of the applications out there.. Very nice product Kevin, kudos to DF on this...
But.... LOL
Kevin, do tell about the CVO integration harness..
And I know some folks have complained about the DF adapters but man I swear, years I've been using these with Polk speakers and never an issue.
Old Jun 28, 2013 | 06:22 PM
Dragonfly2000
[quote
Kevin, do tell about the CVO integration harness.. quote]
The first phase of the CVO harness is a plug and play Line Level converter that simply plugs into the Molex connector that goes to the MTX amplifier part number 760000141. It allows for plugging RCA output right into the OEM harness. Cost is $40.00
Next phase is plug in connectors for all the speakers. We have had mixed reviews on whether people want to spend the $$$$ needed to plug into the OEM plugs VS cutting the ends off. Input would be appreciated on these!!!
Old Jun 28, 2013 | 07:01 PM
MontyCop05's Avatar
MontyCop05
Having some trouble locating these kits on your website...Link?
Old Jun 28, 2013 | 07:14 PM
Dragonfly2000
Web guy working on them now,
we have 4 main kits for maps and they are
23240-13 OEM Fairing Amp Harness, Aftermarket Radio 2 or 4 Channel Amp.1998-Current Electra Glide/Road Glide
23210-13 OEM Fairing Amp Harness, OEM Radio 2 Channel Amp.1998-Current Electra Glide/Road Glide
23220-13 OEM Fairing Amp Harness, OEM Radio 4 Channel Amp.1998-Current Electra Glide/Road Glide
23230-13 OEM Fairing Amp Harness, Ultra Classic 1998-Current, Electra Glide/Road Glide
Let me know which of these you would be looking at and I can get you the pricing.
Old Jun 28, 2013 | 07:37 PM
MontyCop05's Avatar
MontyCop05
How about you tell me which I would need... I have a 2010 Ultra with a soundstream 4 ch amp, and 4 polk speakers (2 fairing, 2 tourpak pods), and I will be soon installing a Sony headunit with the biketronics radio adapter and the hogtunes tweeter pod.
Old Jun 28, 2013 | 08:47 PM
Dragonfly2000
Thats the 23240-13 with no line level converters at $45.00
Old Jun 28, 2013 | 10:13 PM
MontyCop05's Avatar
MontyCop05
Great...are you posting any pictures of the kit on the website soon? Also, pardon my ignorance here, but what is the benefit of your kit? Ease of install/repair/removal? I already have the amp and speakers hooked up, did all the wiring myself with some soldering and also connectors. I'm guessing this eliminates that mess of wires and makes everything "plug & play?" If so that would be an improvement I'd want to add when I install the new head unit and tweeter pod.
Old Jun 29, 2013 | 01:11 AM
BrownSanta's Avatar
BrownSanta
subscribed
Old Jun 29, 2013 | 03:49 PM
Dragonfly2000
Default Pics of the NEW DIY Haresses
Here are the first of the pics. Power wires are 12 GA Stinger brand with crimped ends with heat shrink/glued casing. All speaker wires are Stinger 16 GA and aready have large and small spade connectors, for speakers, as well as Male Bullet connectors for putting into amp lug.
All kits come with water proof fuse holder and 25 amp ATC blade fuse.
Any kit for an OEM radio comes with a line level converter, and Ultra kit 23230-13 comes with two so that you can retail Fader option on bike.
New "diy" audio harnesses for baggers-harness-pic-resized-23210-13-front.jpg
New "diy" audio harnesses for baggers-harness-pic-resized-23220-13-front.jpg
