I have a 2010 Street Glide that is having a issue with the Radio. I'm getting error code 1 and error code 33. While the radio is on a fm station I can hear the unit trying to process a CD and error code 1 will flash on the display . Checked to make sure that there wasn't a CD in and confirmed that there wasnt .Can any one help me with this?
never seen error code 33. 1 means the radio is toast.
I would contact Tony @ Iron Cross Audio and he'll be able to help you with that one.
I have a 08 SE UC that has no audio output at all. The front and rear headsets function normally and the inputs to the amplifier show almost 6 volts at the amplifier connection for the left-right front-rear channels. If i take the the aplifier input for the speakers and attach speakers they all play but there is no front to rear fade. Tried swaping the amp from my buddies 09 which was a "B" amp with no change. I have all the open codes for speakers which I read is normal and they go away with direct wiring to speakers. Any ideas? kinda confused.
Thanks, I completely forgot about the speaker switch! I will check it out and let you know what I find. Now that I have the EDM I can finally make some sense of this system.
I would like to thank UltraNutZ advice within post 210. He was, sadly enough, correct with his hint and my radio is broken. I had to replace it.
Further comments within Sticky ASWC-1 / Metra install.
Haven't done this check yet but will asap, my stereo just quits playing but the power stays on. I have to turn the power off and on then it starts up again, and it doesn't matter what mode it is playing in. Had a couple ppl tell me the head unit is junk.
Even though this thread is five years old, I'd like to thank Harleypingman for posting it, and HDForums for making it a sticky. My speakers just quit working on my last ride, and because of this thread I learned how to run the diagnotics, find the fault, and also the repair shop I can send the unit into.
I got the apparently common B2017 fault, front speakers open, but again, because of this thread, I discovered that my never used Harley headset will work when plugged in, so I can continue to enjoy the tunes as long as the weather holds, and with winter coming, I have lots of time to remove the unit and send it in for repair.
