Anyway to diagnose a radio on a 2000 FLHTC? I had the radio and amp and volume control on the hadle bars replaced in 08 because of a short in the system. It was replaced unde extended warranty thru the dealer. It was a direct OEM replacement supposedly but I think it was actually a refurbished radio and amp. Anyway the new symptoms are that the front and back left sid espeaker is cutting off and on I get a lot of satic when hitting bumps in road. Any thoughts would be appreciated.
Thanks,
Call Radio Sound: (502) 267-6768. RS was HD's vendor of the radio in your bike. Ask for customer service; they're very helpful.
I think I have a stuck or open radio switch. It does not say it on the dig. screen, but I have poor or no radio signal. Can I fix this or does it have to go to HD. 2008 EG out of warranty .
Thanks.
Find it a lot easier to pull the HK out and sell it on Ebay. 800-1000 bucks. Spend that money at biketronics and your problems are gone, and you get a way better stereo in the end. Just my opinion
I guess if you have a police bike and aren't used to the intercom, CB, and water resistance of the stock radio that might be a good suggestion. If you like the features of the HK just send it to Iron Crosse and get it fixed, much cheaper solution.
Send it in for repair. Happened to my 06 3 times. The first time under warranty. The last time I lived with it for a year before I sent it in. I then had to take it to the dealer to have it calibrated. They set up for the country you live in.
Great info and timely for me. Yesterday, my radio just started changing channels randomly. Sat overnight and today it was good. Will have to check. It might be a pinched wire as they just replaced the cruise control switch.
Appreciate you sharing.
