Upgrading from Hogtunes...a piece at a time
I understand all about the series/parallel wiring principals and how they work to keep the load where you need it to be. I have taken into consideration that my speakers are 2 ohm, and that replacements will be 2 or 4 ohms. I'm thinking of either a Rockford 2ch, or the Soundstream (or PPI equivalent) 2 or 4ch. Also planning Polk mm651 2.7 ohm speakers,at least in the fairing, maybe the lowers too. I need to keep the fader function, so I might also get Polks in the rear pods and run off the rear channel of a 4 ch amp, having the front 4 off the front channels, or a separate 2 ch amp for them. If the lower speakers aren't even worth it, I'd run 4 Polks off a 4ch amp. Fairing and rear pods.
So now for the questions. Which gives me the most improvement, replacing the amp, or the speakers first? I'm looking for more sound quality than I currently have. If I turn up the bass where I'd like it, it seems to push too hard, and into distortion. I guess my main questions would be 1. Would the Hogtunes speakers benefit from a better amp and more power,or are they at the limit of how good they would ever sound?
2. Is the amp good enough to keep and upgrading the speakers is more important?
I'd likely do either speakers or amp this year, and the other next season. I'd also try selling anything that gets replaced to help pay for the next upgrade. I know this is long, but I'm looking for someone that might be experienced in the components I'm currently running. Thanks for any help.
- replace fairing speakers with the Biketronics BT7P1 7.1". When you install these make sure to use polyfil around them.
- replace lower pod speakers with the BT7P1 as well (providing they'll fit) and line the pod with polyfil as well.
- when the above is installed, wire both pair of speakers in parallel creating a 2 ohm load at the front channel of the amp.
- replace rear speakers with the Polk MM651 speakers making sure to line the pod with polyfil as well. When you install these they will need to be re-wired to be connected to the rear outputs of the amp
- replace amp with another 4 channel amp that can really wake this speaker combination up and make them come alive for you.
- and since you stated "for now" if you're going to go through all of this, I would replace the head unit as well.
My recommendation:
BT7P1 - 249/pr = $500 (these come with adapter rings)
MM651 - $140
Polyfil - $15
Soundstream PN4.520D - $100 (be aware of FM reception issues)
Biketronics BT1000 Handlebar Control Module and Install Kit - $197
CD - Sony CDX-GT700HD - $110
OR
iPod - Sony DSX-S310BTX - $130
so for about $1100 you will have a pretty bad-azz system that you'll be happy with and your friends will be envious of.
Saturday at House of Harley on S Layton ave. has a "park and pound" bike sound competition. Hope this link works.
http://houseofharley.com/en/events/a...casa-de-harley
