I've got MM651's in the fairing and a PBR300x2 and its worked flawlessly for almost 6000 miles on my 2013 ultra. On saturday I started the bike and had no sound out of my front or rear speakers. My amp is hooked to the MM651 speakers in the fairing only. Troubleshooting tonight I learned these things:
Power to amp is good but nothing lit up on amp when stereo on.
Ran a jumper wire to the remote input on amp, then the amp lights up.
Unhooked the amp and wired the head unit to one of the MM651 speakers directly and still no sound, front or rear. I do have sound through my helmet headset.
Ran the DTC and here's the codes:
b2022
b2021
b2020
b2017
b2023
Is my head unit fried? If so can the PBR300x2 cause it? Will the factory warranty cover it even though I installed aftermarket speakers and amp?
I appreciate the help and thanks in advance!!
b2022
b2021
b2020
b2017
b2023
how are your rear speakers connected?
all of the above codes reference the speakers and are to be expected when you have an amp in the system. the head unit is looking directly for a speaker/load but instead it's finding no speaker because the amp is inline.
any idea what would cause an amp to feed back into the audio outputs and toast a head unit? This is certainly a first for me...
At first we thought it was an improper install, but we had a repeat customer who we were pretty confident with that had an immediate repeat failure after a repair.
Something is shorting, but we've not had the opportunity to get our hands on one of the alleged bad amps
just out of curiosity Tony, was it a PBR300x2 or a PBR300x4? The latter I could understand with the severe heat issues RF had with them initially so it may be an older amp.
