No Amp for a 2012 FLHTK?
Old Sep 4, 2013 | 11:54 AM
Talldog's Avatar
Talldog
Default No Amp for a 2012 FLHTK?
Not sure if I'm missing something or what. I've got a 2012 Limited and I just installed Harley's Boom Fairing speakers.
Sound is better, but now I'm thinking of adding an Amp.
I would like to stick with Harley, but looking thru the parts book, it doesn't look like they list an Amp that will fit inside the Fairing on my Limited.
They list one that mounts in the Tourpak, but mine is detachable and I don't normally have it mounted to the bike.
Am I out of luck in getting a Fairing mounted Harley Amp for the two Fairing speakers?
Old Sep 4, 2013 | 12:16 PM
Molarman's Avatar
Molarman
Why stick with Harley? It would just cost more and underperform.
Old Sep 4, 2013 | 12:45 PM
John_HD's Avatar
John_HD
I use the Rockford PBR 300x2, fairly easy to wire.
Old Sep 4, 2013 | 06:01 PM
GLACIERPEARL's Avatar
GLACIERPEARL
You should have checked in BEFORE you bought the BOOM speakers. Can you take them back ?? If you are going to add an amp, there are many speakers in the BOOM price range that will blow them out of the water !!
Old Sep 4, 2013 | 06:10 PM
Pioneer74's Avatar
Pioneer74
That amp will overpower the Boom! speakers.
To the OP, if you want to stick with your HD speakers, get the Hogtunes 40.4 amp. It will be less expensive and easier to install than the Harley amp and won't overpower them. Also, the harness that comes with it will leave the rear speakers detachable if your current setup already is.
Old Sep 5, 2013 | 06:59 AM
UltraNutZ's Avatar
UltraNutZ
if you insist on sticking with HD components, then use KIT # 76000070.
leave your rear speakers plugged directly into the back of the radio.
Old Sep 5, 2013 | 12:41 PM
John_HD's Avatar
John_HD
The last step of setting up the amp is adjusting the gain for the speakers. If you do it right the amp is fine and he'll have plenty of power when he changes the speakers in the future.
No U Glider
Audio Systems
30
Oct 28, 2016 10:42 AM
GLYDN
Audio Systems
Sep 26, 2016 12:10 PM
booch
Jan 11, 2012 06:59 PM
joe mayo
Jan 1, 2011 03:18 PM
GOSTAZ
Jul 18, 2010 07:46 PM
