2ohm v. 4ohm amps; impedence mismatch
Old Sep 5, 2013 | 03:05 PM
jefla's Avatar
jefla
Default 2ohm v. 4ohm amps; impedence mismatch
I've an SG w/ 2 fairng spkrs and plan to stick w/ 2. Currently I'm running the OEM headunit, Hogtunes 70.2 amp (2ohm), and Focal PC 165 (4ohm). Polyfilled the fairing. Thing sounds great but sometimes at high volume it looses clarity, which I assume is due to the impedence mismatch.
How should I fix this? Upgrade to a 4ohm amp or get 2ohm spkrs? When I picked the Hogtunes amp I was not so knowledgable and was pretty concerned about keeping weight down (weight factors into all my mods). I've been through two sets of spkrs before getting to the PC 165, wh/ are not light. If I change amps I'll get somewthing made in the US and so I'm leaning toward Hawg Wired. Evenutaly the OEM HU will go, mostly because I want blutooth.
Thanks
Old Sep 5, 2013 | 03:29 PM
Pioneer74's Avatar
Pioneer74
You're losing clarity because the 70.2 is not powerful enough to get everything out of those speakers.
Upgrade the amp.
Old Sep 5, 2013 | 03:50 PM
UltraNutZ's Avatar
UltraNutZ
Upgrade the amp.
Old Sep 6, 2013 | 02:54 AM
KILRBUSA's Avatar
KILRBUSA
JEFLA-get a Rockford pbr300x2 and you will be set, has plenty power to rock those speakers and it's not gonna break bank $130 new on eBay. And yes it fits on top of HK unit behind batwing fairing.
Old Oct 28, 2013 | 08:17 AM
Tkstoy's Avatar
Tkstoy
How is everyone wiring the PBR 4 channel set up or 2 ?
Old Oct 28, 2013 | 08:19 AM
UltraNutZ's Avatar
UltraNutZ
you might want to be a little more specific about your question Tkstoy to get an educated answer.
Tell us what you're trying to do and with what equipment and with what bike
Old Oct 31, 2013 | 12:03 AM
jefla's Avatar
jefla
Update-ish. Got a BT-454 but have not installed it. Holding off because I've finally hit the wall with the HK headunit. I gotta have bluetooth. Now I'm hu shopping. I'll pick one w/ CD and BT that's totally plug & play and that utilizes all the hand controls, plus avc.
Old Oct 31, 2013 | 04:42 AM
GLACIERPEARL's Avatar
GLACIERPEARL
And so it begins.....................go big or go home !!
tidbit1
Apr 9, 2018 05:50 PM
SFDonovan
Audio Systems
Oct 11, 2016 06:19 PM
jefla
Audio Systems
22
Sep 24, 2013 08:41 PM
Rockrivr1
Audio Systems
13
Apr 8, 2013 11:39 PM
shore
Feb 28, 2011 01:48 PM
