Going NutZ again!
Old Sep 15, 2013 | 10:01 AM
Pioneer74's Avatar
Pioneer74
Good luck and keep us posted. Running the speakers 50% past specs is going to prove one of two things. Either those speakers are really good, or how well Biketronics warranty is.
Personally, I hope the speakers are that good. Over the winter I'm going with the exact same setup except for the Pioneers in the bags and the BT4180 amp. Is supposed to be rated at ~230w a channel at 2 ohms, and I can keep my quick detach for the Tour Pak.
I'm sure I speak for everybody when I say we expect many pictures and a detailed write up of the installation.
Old Sep 15, 2013 | 10:19 AM
UltraNutZ's Avatar
UltraNutZ
well.. in all reality I will never run them that way however they are HATs. I promise you they'll take a LOT more than 100w RMS without issue.
I already have about 30 pics of cuttings, engravings, all pretty much in preparation of doing it right once the plastics come in.
Old Sep 15, 2013 | 12:27 PM
GLACIERPEARL's Avatar
GLACIERPEARL
Originally Posted by Pioneer74
Might want to think about running a capacitor for each amp too. That's going to be a big draw on your charging system. I don't see how it will be able to keep up.
Charging system won't be a problem. Been running 5 years with 2of the Apine PDX 600 watt amps, with no problems. Shouldn't need a cap either. Bass is what spikes the voltage, and I run 4 6x9s without the need.....
Most people use caps unnecessarily ...
Nuts, did you order your lower speaker boxes yet . Still dragging my feet on adding those. Should sound pretty good when you get her finished !!!
Old Sep 15, 2013 | 12:37 PM
UltraNutZ's Avatar
UltraNutZ
The cap I only bought "in case" I need it but I highly doubt I will.
I did yes sir.. Bought them from fairing factory and they fit perfectly to the $134 lowers I bought off eBay. Working on my 2nd coat of water sanding (1200) the primer as we speak. One more coat of primer, another water sand, dry em up and spray em black. It's going to be a few days before I get my HD hardware for the lowers to put them together but that'll give me time on the black to hopefully perfect it to look like the lowers and cure properly.
Old Sep 15, 2013 | 12:54 PM
GLACIERPEARL
Are the boxes from Fairing Factory better/and/or cheaper than the CVO boxes ??
Old Sep 15, 2013 | 01:05 PM
UltraNutZ's Avatar
UltraNutZ
no cheaper no better. just available. my local dealers didn't have the pods, was going to take 2 weeks to get them and any of the online stores like LSHD were 2+ weeks out as well. They were $105 shipped from cruiser-life on fleabay
http://www.ebay.com/itm/230709433372
Old Sep 15, 2013 | 01:35 PM
2000 FLHTCUI's Avatar
2000 FLHTCUI
Is there any chance of that TN4.900 amp fitting on top of an aftermarket radio under a batwing? I know it's wider than the PN4.520.
Old Sep 15, 2013 | 01:42 PM
UltraNutZ's Avatar
UltraNutZ
I would say no but I will confirm for sure for you in the next few days once I get everything pulled apart
Old Sep 15, 2013 | 01:45 PM
2000 FLHTCUI
Thank you. Wouldn't that be sweet and open up a ton of options?
Old Sep 15, 2013 | 02:00 PM
Pioneer74's Avatar
Pioneer74
It would make me think twice about the BT4180, but it sure would be nice to have FM back. The downside of these Soundstream amps.
