The Official 2014 audio upgrade thread
Old Dec 18, 2015 | 01:55 PM
  #2001
captjac's Avatar
captjac
Originally Posted by hbsoldier3
Just placed an order at BikeTronics for the BT 4180, BT7P14 (not pro), Breakout harness and two Bt-355 line leveler's. Gonna pair with the Alpine SPR 60's in the rear as Bill from BT suggests. All in for less than 1K, thanx BT.
Is there a thread on how to remove the stock fairing speaker pods? Did a search, but have had no luck.
Thanx in advance,
Paul
:ico n_tree:
Paul,
If you are trying to remove the front pods start with posts #50, #130 & #137 of this tread. There is a lot of info in this tread just gotta wade through it.
Old Dec 18, 2015 | 03:29 PM
  #2002
hbsoldier3's Avatar
hbsoldier3
Originally Posted by captjac
Paul,
Thanx for the intell, I like the color of your bike.:icon_snowman :
Old Dec 20, 2015 | 01:28 PM
  #2003
Camron92's Avatar
Camron92
Stage I
Originally Posted by QWKHOG
Have read through this and wanted to ask if HU re-flash is done through the USB port or CanBus connection? I recently installed the Arc Audio M.P.A.K. 8 kit and will need to flash to correct DSP. The install was involved but all fit really well.
The kit includes everything to install but switched out 12-gauge mains with 8-gauge direct from bat w/30 amp fuse off battery. No factory wire cutting w/kit
Here's a picture of amp install.
Curious what are you running your amp at high pass or full? Also what is your crossover set to? I can adjust gain based on my preference but currently i have mine on full and cross at about 150 it sounds good but to avoid distortion i feel like im not getting the volume i should be?
Old Dec 23, 2015 | 09:11 AM
  #2004
flight risk's Avatar
flight risk
After reading many threads, pages, and recommendations, I am more confused now than ever before.
I have a 2014 Electra glide and am planning to install (on a budget) the following equipment.
- Rockford fosgate PBR300 x 4
- Polk MM651 front fairing
- Alpine SPR60 rear pods.
Are there any reasons this system shouldn't be:
1) easy installation, except for maybe a few mods for the amp bracket
2) Plug and play
3) no other accessories except maybe a wire, connector, or miscellaneous adhesives.
Any other information would be great from you guys-
thanks
Old Dec 23, 2015 | 09:13 AM
  #2005
flight risk
oh.... And sound good!!!!!
Old Dec 23, 2015 | 10:21 AM
  #2006
UltraNutZ's Avatar
UltraNutZ
2) Plug and play
thanks
1. easy, yes pretty much. just take your time
2. the only way to make this plug and play is using customized wiring harnesses made specifically for your install. To my knowledge the only company out there making custom (to your specifications) harnesses is V-Twin Audio and they're not cheap.
3. yes other stuff is required.
so here's my thoughts.
If you're going to use that amp, you'll need to select a different pair of speakers for the fairing. The amp is only stable down to 4 ohms and those MM651 speakers are 2 ohms. You'll wind up with an amp that overheats and clips on you. The rear pod speaker selection is fine with the SPR60 as far as function is concerned but with that being said, my suggestion based on experience and lack luster performance of that amp is find another amp to use for your project. It's only stable at 4 ohms and is lacking in performance. Those SPR speakers at 88db sensitivity are going to want to see about 100w of clean usable power to make them shine.
The other thing you're going to need regardless of which amp and speaker choice you make is this line leveler from Biketronics that will clean up the crappy audio signal coming out of the stock radios on these 14 and up models.
Hope that helps bud.
Old Dec 23, 2015 | 05:25 PM
  #2007
flight risk
Understand- Thanks. I chose the amp for cost and not necessarily for performance. I liked the BT but it was more than twice the cost.
Any budgetary install suggestions.
I am not a music/clarity aficionado, so I can live with a lot of irregularities. Although, I have to say, I don't like distortion.
Old Dec 23, 2015 | 06:19 PM
  #2008
UltraNutZ's Avatar
UltraNutZ
you're kinda in a catch 22 here because of the amp.
1. if you use that amp, it much prefers to be used with speaker level inputs which negates the need for the BT Line Leveler
2. If you use speaker level inputs instead of RCA inputs then you have no control over what the system will sound like because you're not using the line leveler to "condition" the sound before it gets to your amp.
IF, and I say it again, IF - FM reception is not important to you then there are a lot of amps you can choose from that are economical and powerful enough to drive 2 pair of those SPR60 speakers. Soundstream PN4.520D is one, Power Acoustik RZ-2000D, among several other class D amps. But be forewarned and it's hit or miss at best; you might lose or degrade your FM signal by using some of the class D amps. Just the nature of these amps. BT among many other vendors here and on the internet has figured out the FM issue and their amps don't interfere.
Old Dec 24, 2015 | 06:55 PM
  #2009
02BlueDeuce's Avatar
02BlueDeuce
UN I'm running the RF PBR300x2 and infinity speakers like so many others on here are doing. I'm currently using the magic box rather than a flash. Would you recommend I get rid of the magic box and place the BT355 in its place?
Old Dec 25, 2015 | 07:15 AM
  #2010
UltraNutZ's Avatar
UltraNutZ
Deuce, I would call Bill @ BT. He'll shoot you straight (regardless if it's their product or someone else's) on whether or not you should replace the magic box with their line leveler. I have a suspicion he'll tell you just stick with what you have but maybe not.
