The Official 2014 audio upgrade thread
Old Oct 2, 2014 | 07:56 AM
  #981
UltraNutZ's Avatar
UltraNutZ
Originally Posted by boham
Hello everyone! First post here.
I purchased the Hawg Wired speakers because I heard how awesome they sounded on another buddy's 2013 Ultra Glide. I didn't pay attn to how much different his and my 2014 FLHXS really was so I bought the same speakers. So yesterday morning, I wake up and decide to embark on installing them and found out that while the speaker fits in the plastic speaker box, the box no longer fits into the faring properly.
I decide to email them about it to see if anyone else had this problem. While I was waiting on a reply, I found this forum and read most of what is in this topic here. I'll have to admit that this topic started to confuse me since I was unable to come up with a definite answer. I eventually got a reply from Hawg Wired. Here is their reply...
So here's my question. I already have the speakers and an amp (Rockford Fosgate PBR300X2). Do any of you think the grills would work? Also, If I do decide to purchase, do I need to get my stereo flashed? It's the SGS with the touchscreen doo hickey.
Before I put those ugly vtwin grills in there I would opt for the Boom Audio grills instead. Also depending on the depth of the speaker from the front edge to the back of the magnet you might be able to take the pod apart and mount the speakers from the inside and that will allow you to retain the stock grills.
Yes you will need to get the radio flashed per Rockford Fosgate's instructions/tech bulletin on their website.
Old Oct 5, 2014 | 06:09 PM
  #982
QWKHOG's Avatar
QWKHOG
To Mr. Neptune - post 979
Also posted (#970) regarding flashing factory radio without a response but figured it out. There are many brands to pick from but choice depends on if staying two or four channel.
I decided to stay two channel only for simplicity and installed Arc Audio M.P.A.K 8 kit.
With most brands would recommend:
1. High end 2/4Ch Amps follow the Fosgate service notice and have Harley re-flash radio for Amp 1 - No, Amp 2 - No, with 8-speakers option. A must to correct/remove DSP from radio.
I know this seems odd for only a two channel system but it made a huge change to high volume clarity with my system.
2. Install 8-gauge mains vs 12-gauge included in most kits. (Personal choice)
3. Install Dynamat on backside of speaker pods. (stopped the vibration/chatter)
4. Set crossover to Full and adjust gains to 50-60%.
Old Oct 8, 2014 | 11:30 AM
  #983
hdcrzy's Avatar
hdcrzy
6th Gear
Default Speed Dependent Volume Bug
Originally Posted by RoadKingClassicNE
I just had my stereo upgraded on my 2014 Limited with the speakers and amp. Now, when I start my bike, the sound is lower then with the stock speakers when turned up. After I get going down the road, I then go into audio settings and move the speed volume down to the second bar and the sound almost triples in loudeness. I can then move back to 4 bars on the speed volume and all works well and sounds great until I shut it off again.
Dealer told me to shut off the speed volume and that was causing the amp to "overload" but when I do this the sound is not even half as loud.
Any ideas of what is causing this? How do I explain the "flash" I have read about and how do they disconnect the DSP?
I just had Boom Audio amp and 4 speaker kit installed yesterday on a new 2014 Ultra.
I experienced the exact same problem as you when leaving dealership, with one difference. So far my has stayed at higher volume and speed dependent settings function properly,
I've started, stopped and let it set overnight and all us well still today.
I called dealer tech to let him know and he's scratching his head.
Update: Mine is doing just like yours, every power cycle or restart causes volume to revert to very low level.
Going to speed setting makes it come back on every time.
What's the fix?
Old Oct 10, 2014 | 12:12 AM
  #984
Sam2010's Avatar
Sam2010
I have experienced that volume issue with my 6.5 radio and I have no amp yet....
Old Oct 10, 2014 | 07:18 AM
  #985
RoadKingClassicNE's Avatar
RoadKingClassicNE
What's the fix?
Thanks for the feedback. Mine still does the same thing everytime I shut it off. I have got used to it now so guess I wont worry about it unless someone figures out a fix for it.
Old Oct 11, 2014 | 02:31 PM
  #986
SunPilot's Avatar
SunPilot
Well, I have a 2014 SGS with a detachable tourpak. My girlfriend wants a cup holder and I see everyone else mounts the cup holder between the speaker pod and the pak...so...Now I need to install speakers in the back (sound for her, and a cup holder!)
Since I am doing this, and not wanting to take out a mortgage, and do it for a fair price...I suppose I need:
2 speaker pods
2 rear speakers
Upgrade ft. speakers
amp...or two?
flash
Whew...my questions (I read all 99 pages and I am still confused...so many ideas and options...needed extra strength Tylenol by the time I was done.
Are there aftermarket pods that fit and look good on 2014 bikes, as opposed to stock (which from what I gather have trouble fitting better speakers)
Which are good quality speakers...front and rear, that won't kill my wallet?
Two separate amps, or one four channel amp...any differences or advantages to either setup?
I don't believe I need a Magic box if I get the proper flash (I realize I need flashed anyway because I am going to four speakers.
All this for a cup holder (and some sugar after a ride LOL)
Fellas, I appreciate any input, and sorry for the long post
Old Oct 11, 2014 | 03:48 PM
  #987
UltraNutZ's Avatar
UltraNutZ
a coozie in her hand would be much cheaper!
infinity kappa 62.11i front
infinity kappa 62.11i rear pods
the pods from June's upholstery should fit the 14 tourpak but you might want to call them to make sure. http://www.junesupholstery.com/
alpine MRV-F300 amp
Old Oct 11, 2014 | 05:09 PM
  #988
SunPilot's Avatar
SunPilot
alpine MRV-F300 amp
It really would, but...gotta keep the little lady happy...besides, I can use some better sound.
I'll check out June's...thanks
Does that amp give enough power to drive the speakers at highway speed?
Old Oct 11, 2014 | 05:35 PM
  #989
UltraNutZ's Avatar
UltraNutZ
I have to say that I don't have any first hand experience with it but I've talked with a couple of guys that are running it. The consensus is it's great to run 6.5" speakers with and plenty of volume at highway speeds, doesn't interfere with FM reception, fits in the fairing, nice price tag.
Old Oct 11, 2014 | 05:53 PM
  #990
SunPilot's Avatar
SunPilot
I'll definitely look at that amp...I was looking at the J&M stuff...I'm sure it's high quality, but the prices...way too much.
