RF or BT
Old Dec 19, 2013 | 04:53 PM
  #31
UltraNutZ's Avatar
UltraNutZ
good point.. maybe I'll do it this weekend after changing cams again for the 3rd time.
Old Dec 31, 2013 | 09:40 AM
  #32
uwiik's Avatar
uwiik
Originally Posted by floridapoolboy
I have a question about the Biketronics amps. They say they are using UcD technology, is this a class D amp? And if so, does it screw with FM like other class D amps? I'm planning on swapping out my PBR300x2 for a 4 channel amp when I install my lowers, but I'd like to keep my FM if possible.
I used 2180, no FM issue whatsoever even with the el cheapo freebie yellow wire BT called an antenna...
Old Dec 31, 2013 | 10:04 AM
  #33
UltraNutZ's Avatar
UltraNutZ
got around to doing an install for another member here over the weekend using the HT lids. I have 1 complaint about them and that is the cheezy glue used on the wear plates that latch inside the back of the lid to the saddlebag. IMO you should go to HD and get you a set of HD wear plates. Part # 90962-93. With the HD version once you stick them you better make sure you get it right because they are not coming off.
The wear plates provided by HT WILL fall off.
bmayy71
Aug 25, 2016 10:33 PM
twp98
Audio Systems
Feb 25, 2016 04:05 PM
clackavosticus
Audio Systems
Oct 19, 2015 11:41 AM
Night_Train
Touring Parts
Jul 5, 2013 03:44 PM
pennstater
Jun 1, 2011 07:31 AM
