HD Plus Ipod Player
Old Jan 20, 2014 | 12:45 PM
Gonzy's Avatar
Gonzy
Gonzy
Originally Posted by Iron Cross Audio
Bit confused.
When we asked where power and ground were connected to, this was what we were concerned with. If you had connected everything as per instructions, your power to the module would be constant, not switched. The module cannot be connected to switched power. Once communication is established with the radio, constant power is needed to prevent loss of that communication. Constant applying / removing power from the module can result in a defective module (as probably happened here). We would like to help you directly, but you need to call / email us.
Perhaps there is some confusion on my end. When I said switched power I meant the same one that powers the radio, so when the radio is turned on I believe the same line is powering the HD Plus. So in essence it is powered by the radio and not a separate switched line, so mea culpa for that confusion. I don't want to post my email address here so I will email you via your site with my address and look forward to any other insight that you can give, but everything is as I outlined in my post.
Old Jan 28, 2014 | 09:00 PM
Gonzy's Avatar
Gonzy
Gonzy
Default Update to HD Ipod Plus problem
Just want to update about my problem with my HD Ipod Plus player. I want to thank Tony at Iron Cross Audio for looking at my account and seeing that I still had a warranty and to send the unit back for repair or replacement.
Rather than waste everyones time, I thought I would take another look at the connections. The ground was good, then I looked at the hot wire and saw that the connection was made with one of those quick connect taps. I stripped that off and saw that the tap was starting to cut a few strands of wire. I then stripped a section of the hot wire, spliced in a new wire then soldered the spliced in wire. I think that has taken care of that problem.
As to my original problem with the unit freezing up, it was still there. So I played around with the connection to my Iphone 5S and so I feel the problem is in the lightning connection. The connector being small just gives a little of slop if it's not in there in just the right way. I think I might just look for an Ipod with the old style 30 pin connector, that might be a better way to go.
So the big lesson here is if you're going to install the Ipod player, throw away those quick connect thingamajigs and solder the connections in or find someone who can do it for you.
LQQK_OUT
Jan 28, 2024 07:07 AM
roadrash2012
Oct 26, 2013 04:38 PM
TxDeuce
Sep 10, 2009 12:10 PM
bruno13
Apr 1, 2008 10:54 AM
IndyRider
Oct 15, 2007 03:19 PM
