Hawg Wired?
Old Jan 14, 2014 | 04:43 PM
BlessedHellride's Avatar
BlessedHellride
Default Hawg Wired?
Hello audio pro's,
when talking to a bud of mine about sound upgrades for my 2013 FLHX, he pointed me to Hawg Wired (as in, its his preferred upgrde when he gets around to it), so I thought I'd look round the forums and search but not finding much on them. Seen a few Biketronics recommendations but most seem to lean toward the Polk speakers w Amp and maybe a name brand head unit. Plus J&M seems to be all over the place, too.
I do notice that Biketronics, HW and J&M are priced into the outer atmosphere when compared to the Polks etc.
So, is it a bang for your buck type of thing? Get the same bang out of Polk/Rf amp, for less buck? I'm leaning towrd the RF pbr300x4 and Polk mm651 fairing speakers (pbrx4 so hat if lid speakers are in my future, I'm ready in that regard).
Thx in advance.
Old Jan 14, 2014 | 05:04 PM
Pioneer74's Avatar
Pioneer74
Thx in advance.
The pbr300x4 is historically known to run really hot. The Polk MM651 speakers are 2 ohm speakers, and the pbr300x4 is 4 ohm only so you have to decide which one you want more.
If you are looking for "bang for the buck", then the Soundstream 4.520 amp might be for you. The downside to that amp is you will lose all FM and AM reception. If you want to keep FM reception, there are options, but they cost more.
The pbr300x2 is a good amp. You could get one of those for your MM651's and then add another one (you can fit two in your fairing) when you add bag speakers.
Old Jan 14, 2014 | 06:34 PM
badazzpred's Avatar
badazzpred
Just Curious Pioneer74 do you or anyone/threads have any pics of an Install of 2 PBR300x2 amps in a batwing fairing as this has my attention?
Thanks
Old Jan 14, 2014 | 06:48 PM
Pioneer74's Avatar
Pioneer74
Thanks
None that I know of, but it's pretty straight forward. There are two ways to accomplish it.
1. One amp is mounted on top of the radio, long way from speaker to speaker, and the other is mounted on the Hogtunes 2nd amp bracket. It replaces a fairing brace with a mountable bracket. So one on top of the radio, one on the side. This is the most common.
http://www.ebay.com/itm/Hogtunes-Amp...b1fc87&vxp=mtr
2. Both are mounted on top of the radio, side by side, long way from front to back of the bike. They are long enough that when you do it this way, you have to trim some of the fairing gauge braces off of the inner fairing. Most people don't want to do that, that is why they prefer to use the bracket.
Old Jan 14, 2014 | 11:27 PM
GLACIERPEARL's Avatar
GLACIERPEARL
Skip Hawg Wired, and skip the PBR 300/4.............What's your budget ??
Old Jan 15, 2014 | 05:25 AM
BlessedHellride
Hoping to keep it around $400, I'm not really interested in replacing the head unit. Fairing speakers and amp only. I read a lot about guys just getting away with replacing the speakers and then get others saying an amp will provide even more improvement. I sold footboard pans to a guy on CL and we got into the sound systems, I was telling him I'm close to pulling the trigger on a J&M Rokker 7.1 w amp setup and he says save your $$ and he originally directed me to Polk db651 with the pbrx4 amp and pricing that on ebay (with an amp mount, speaker rings and fairing foam) puts it right at around $300 (which is less than half the cost of a J&M setup). Got to reading about mm651's and for the few dollars more its said those are better speakers.
Old Jan 15, 2014 | 06:51 AM
UltraNutZ's Avatar
UltraNutZ
Hello audio pro's,
Thx in advance.
your bud has very low expectations IMO.
Your ticket to best affordable sound setup on a street glide with 2 speakers is a Rockford Fosgate PBR300x2 and a pair of Biketronics 7.1" speakers. This coupled with an amp install kit (necessary wiring) you'll be in it for less than $400 and it ROCKS
IMO if you're going to go with lids later on, you're MUCH better off with 2 of the PBR300x2 amps instead of the PBR300x4. The 4 severely lacks power. 2 PBR amps will fit inside the SG fairing without issue using the Hawg Wired 2nd amp mounting plate.
Old Jan 15, 2014 | 11:36 AM
BlessedHellride
Ok I will check out Bt's 7.1 and will take your (and Glacier's) advice on skipping the 300/4. Thx for the feedback.
Old Jan 30, 2014 | 12:23 PM
Sonny81's Avatar
Sonny81
But the Biketronics 7.1" speakers are 2 or 4 ohms?
Old Jan 30, 2014 | 12:27 PM
UltraNutZ's Avatar
UltraNutZ
4 ohms but the power of the amp MORE than makes up for that.
