Head unit replacement understanding
Old Feb 23, 2014 | 12:05 PM
jcain's Avatar
jcain
Default Head unit replacement understanding
So I've decided to replace the stock head unit on my '06 CVO Ultra. I replaced the factory speakers last year with HogTunes for both front and rear and really like the improved sound.
I've decided to take the next step in replacing the head unit. Placed an order for the Biketronics retro-radio install module kit. I haven't decided on the head unit I want yet. I don't use cd's so the units with the "tune tray" appear to be the best choice and they have an AUX input for my GPS to plug into.
To my question. By removing the stock HU am I to presume that the stock amp under the tour pack will not longer be functional? I know I'm losing the XM and CB modules (don't use either) but will I need to rewire the bikes speakers from the new HU or is this done via the Biketronics kit? Should I consider installing an amp?
Lastly of the couple of offered Biktronics Sony radios that have the tune tray how are the displays in daylight for those that have the units?
Thanks in advance.
Old Feb 23, 2014 | 07:01 PM
Landon's Avatar
Landon
I have a Sony DSX310. Works great and does everything I wanted. Downside is the visability in sun. Very little visible when riding, but no one can convince me to change it out. The performance of this radio is excellent. Will be adding a new amp and speakers this week.
Old Feb 24, 2014 | 01:00 PM
BeerIsMyDad's Avatar
BeerIsMyDad
6th Gear
The Sony DSX-MS60 is a tune tray model that is "marine" grade. It's only real advantage over the DSX-S100 is the high-contrast display that is easier to see in sunlight. A good suggestion is to learn your handlebar controls and avoid looking at the radio while riding.
Also, you will not need to rewire your speakers. The Biketronics kit makes it plug n play.
Old Feb 24, 2014 | 06:16 PM
Gnarl78's Avatar
Gnarl78
I'm no audio guru, but I would think you could send signal from your new head unit to the rear CVO amp.
Old Feb 25, 2014 | 02:18 PM
jcain's Avatar
jcain
Thanks for the suggestions and feedback thus far.
I rarely look at the radio display other than the time. Until now I've pushed audio from my Zumo 550 via memory card and dumping into the stock head unit via AUX cable input. If the Zumo supported pushing sound via Bluetooth I wouldn't need the AUX input on a new head unit.
I'd prefer a red backlit unit to match my gauges but in reality the majority of my riding is during daylight so the color becomes less of a big deal. I like the "tune-tray" feature as I have an iPod Touch I can throw in and off I go.
I'll have the retro radio kit in a couple days. Just need to decide on a head unit and then I suspect and amp at some point down the line.
Old Feb 25, 2014 | 05:25 PM
UltraNutZ's Avatar
UltraNutZ
do you know what hd part # the cvo amp is?
the head unit is simply a matter of preference but I would suggest purchasing something with a minimum of 4v rca outputs for later expansion.
Old Feb 25, 2014 | 06:08 PM
jcain's Avatar
jcain
UltraNutZ,
According to the parts catalog for the bike the amp part number is 76192-06a.
Understood on the 4v RCA's.
Old Feb 26, 2014 | 08:29 PM
jcain's Avatar
jcain
Well finally pulled the trigger on a Biketronics retro radio kit and additional harness. They didn't have the radio in stock I wanted so scored that on Amazon. After feedback here and reading a great many threads I decided on the Sony S310BTX.
They also spent some time getting information on how I could still pass audio from my Zumo 550 audio to the 310. Spoke with Donna about it yesterday and John at Biketronics at length this evening.
Using the 3.5mm audio out as I do now from the Zumo to a 3.5mm female to RCA male Y adapter that plug into the BUS audio RCA in's. The other piece I needed is a "PAC Sony Unilink adapter Auxiliary input turn on" (what a mouthful). This allows the BUS audio inputs to act as an AUX input.
Thanks to all that chimed in and helped give me some tips on moving this project forward.
Old Feb 27, 2014 | 09:00 AM
UltraNutZ's Avatar
UltraNutZ
Perfect!
Quickrunner1
Audio Systems
May 15, 2017 08:03 AM
ElectraGlideSteve
Audio Systems
32
Apr 23, 2016 06:04 PM
Fathertime500
Audio Systems
Mar 18, 2016 12:55 PM
Choopy
Audio Systems
Apr 7, 2014 12:56 PM
TwoBlue02
Apr 11, 2013 07:48 PM
