Two 6x9's or Four?
Old Mar 22, 2014 | 05:29 PM
  #31
GLACIERPEARL's Avatar
GLACIERPEARL
For sure !!
Old Mar 24, 2014 | 01:46 PM
  #32
1sandking1's Avatar
1sandking1
Thanks guys. Stay tuned for install pics and results.
Old Mar 24, 2014 | 02:31 PM
  #33
rerb95's Avatar
rerb95
Hey UN, do you have your ss amps inside the fairing? Or in your bags?
Old Mar 24, 2014 | 04:47 PM
  #34
Pioneer74's Avatar
Pioneer74
Both of his are in the Tour Pak. I think the largest you can fit in the fairing is the 4.520, and the 2.350 with the Hogtunes 2nd amp bracket.
Old Mar 24, 2014 | 05:00 PM
  #35
UltraNutZ's Avatar
UltraNutZ
no way these will fit in the fairings
Old Mar 25, 2014 | 08:25 AM
  #36
rerb95's Avatar
rerb95
I forgot you had the sweet lighted tour pack floor.... Saddle bag it is then.... Thanks!
Old Mar 25, 2014 | 08:35 AM
  #37
Eshaw301's Avatar
Eshaw301
Originally Posted by UltraNutZ
Wire them 1 per channel would be my suggestion
Definitely. I am running my Pioneers in parallel on a 125 watt 2 ohm channel and they sound pretty good but I dont like having to adjust the bass boost on the amp in order to get them to respond how I like. Im thinking that when I get this TN4.900 soundstream installed, with it's 150 watts per channel going to each speaker, then I will be more than satisfied. We'll see....
Old Jul 28, 2015 | 06:40 AM
  #38
kdawg187's Avatar
kdawg187
all depends on your end goal and what costs you're willing to associate to that end goal. and by cost I don't mean just $.
4 speakers in each saddlebag is very doable but the cost there is pretty much all storage space will be gone.
If you do this, big power is going to be your friend. Something like the amps I run would be ideal for this type of setup.
225x4 @ 2 ohms.
wire 2 right inward facing as right rear in parallel
wire 2 right lid speakers as right front in parallel
wire 2 left inward facing as left rear in parallel
wire 2 left lid speakers as left front in parallel
that will bring all 4 channels to 2 ohms and I can only imagine what that will sound like.
couple of things to note if you go that route:
1. make sure to line those saddlebags with material
2. make sure to isolate 2 speakers in each from the other 2 speakers using baffles.
What amp are u using Ultra
Old Jul 28, 2015 | 11:31 AM
  #39
Gannicus's Avatar
Gannicus
This is a very old thread Kdawg and obviously I'm not Ultra. But I think he would tell you the Biketronics BT4180 or the Soundstream TN4.900 will get it done.
Old Jul 28, 2015 | 11:44 AM
  #40
haze324's Avatar
haze324
If you are thinking about putting four two 6X9's in each bag you are going to lose space. Might as well toss an amp in the bag and with bigger space you can toss some serious power in there. Hertz HDP4, Soundstream TN4.900 come to mind!
