Putting a stereo together, couple questions
Right now I have bought a Sony CDX-H910UI Receiver and Infinity 6912M speakers for up front. I think I have decided to go with the The Punch PBR300X4 amp. I know they have heat issues but I am thinking of maybe adding some cooling fins and maybe a computer type fan on it. Seems the Class D amps cause problems with your FM. I also want a 4 channel so I can drive all four speakers when I have the Tour Pak on and I don’t want to spend the extra money on a second amp.
As for rear speakers I do have the stock Pods on the Tour Pak but the Tour Pak is a 1997 and the pods do not look like they could handle a 6 ˝ speaker so I am looking at buying these
http://www.ebay.com/itm/Harley-David.../330686774280?pt=Motorcycles_Parts_Accessories&hash=item4cfe77bc 08&vxp=mtr
I can sell the stock ones to get some of the money back. Now for speakers I am looking at
Infinity 612M
Rockford Fosgate M262B
Not sure which ones would be better. Is there anything else that I should do? I been reading about guys having crossovers but have no idea what they are and what they do.
I was also looking at the Rockford Fosgate M400-4D amp but that also is a D class amp. I am not sure if all D class amps interfere with your FM or just that people were having problems with the Soundstream one.
Thanks
Bruce
Infinity 612M
Thanks
Bruce
Not all class D amps cause interference and to further that even the SoundStream amps are hit and miss. I've installed some that caused the issues and some that didn't. No rhyme or reason to it.
The speakers you're referring to for the rears, I'd go with the inifinity. They have much better specs than the RF speakers do with the 2 main specs being
Sensitivity - 92 on inifinity vs 88 on RF. Higher is better
Power handling - 225 on infinity vs 150w on the RF.
The M400-D has good specs but no way that will fit in the fairing so it will definitely be a saddlebag mounted amp. A little over-priced but it's all about what you want to spend. IMO you'd get just as good of results by using the PBR300x2 with your front and rear speakers wired in parallel, save yourself some money, and mount it inside the fairing.
I have all ready bought the front 6x9's but am still looking at the rears. So what speaker would you recommend for the rear. I was thinking Polk MM521 but seems they are falling apart I am not going to take a chance on them.
Bruce
I was hoping you would chime in on this, seems you know your stuff about stereo's. Ya I am not sure I want to take a chance with a Class D amp because I will be mounting my antenna in the fairing. As for the two channel or 4 channel amps I was not sure you could hook up four speakers to the two channel one but seems you can I will go with that one if I can find a good deal on it. I found the 4 channel one for $137 so if I can come close to that price I will jump on it. Not to worried about the power, I am sure either one will be plenty loud enough for me. Besides if I have it to loud the wife on the back slaps me in the side of the helmet LOL.
The one thing with going with the 2 channel one is that I will have to figure out how to wire a fader in because I am sure the wife will want her speakers to be turned down lower then mine up front. I figured with the 4 channel I would be able to use the fader on the head unit.
What would you recommend for an inner fairing antenna?
Bruce
You say you will not have your Tour Pak on very often. If you go with the pbr300x4, you cut your power output in half most of the time. If you get the pbr300x2, and use 4 ohm speakers, you will have all of your power to the front speakers with the Tour Pak off, and only lose a little to the front speakers when connecting the pod speakers in parallel.
But, thank you...
Bruce
Bruce
