1) What you now need to figure out is the V in the above equation. We know the P and R from the specs above. So, P = RMS output of amp at required ohms and R = ohms the amplifier will see from speaker(s) on that specific channel. In this example P=520/2 (260) (Im running a 2.7 ohm load to each channel) and R=2.7. So P(260) x R(2.7) = 702. Now you need the square root of 702 which equals 26.49 so V=26.49. This is the AC voltage that you will achieve by adjusting your gain(s) on your amp.
Question:
In this example wouldn't it be P=130W, Impedance = 2.7 ohms so V would = sqrt of 2.7*130 = 18.73? The reason I say this is that the load = 2.7 Ohms per speaker and there is one speaker per channel and the power per channel (speaker) is not 260W it is 130W.
you're not setting gains on individual channels, you're setting them based on whether it's a 2 channel (being 1 amp) or 4 channel (being 2 separate amps).
I've not seen but a handful of amps over the years that allow individual channel gain adjustments
I agree you are setting gain for two channels by using the power output rating of two channels but using the impedance of only one of the two speakers connected to those two channels. That seems to be what I am stumbling on. It seems you would use power output and impedance values based on either one channel 130 / 2.7 or both channels 260 / ?, not power of two channels and impedance of one.
because your amp sees a 2.7 ohm load.. not a 1.35 or a 5.4. The load is the same across the 2 channels. The only way this would differ is if you're putting a 2 ohm load on your left channel and a different ohm load on right channel. In that case, I won't be able to help you.
The load is the same or equal on each channel if that is what is meant by across each channel. Each channel of the amp sees a 2.7 Ohm load and each channel develops 130 Watts.
