amp stability
Old May 23, 2014 | 09:05 AM
bayboy75's Avatar
bayboy75
Default amp stability
Picked up a set of mm651's, will one single soundstream 4.520 handle 2 tsd6902r's the polks and the titan xl's or will the 3ohm nature of the polks throw it off?
Old May 23, 2014 | 08:02 PM
Pioneer74's Avatar
Pioneer74
The only way to run it and get max power to those 6 speakers is to run the Pioneer 6x9's and the Titan XL's in parallel, but you will probably be disappointed in the results. You will only have 65 watts going to each of those speakers.
Old May 26, 2014 | 04:43 PM
UltraNutZ's Avatar
UltraNutZ
I'm going to make the assumption that the Titan IIs are in the lowers. If that's the case, then you're best to change out the MM speakers to a 4 ohm speaker, run the fairing and lowers in parallel on the front channel and run the 6x9s on the rear channel.
cskarns
Audio Systems
Mar 9, 2019 07:34 AM
Delgado130
Audio Systems
Dec 27, 2018 02:02 PM
Chucks1911
Audio Systems
32
Jun 22, 2018 09:37 AM
Dew Me
Audio Systems
Feb 11, 2013 12:01 PM
pennstater
Jun 12, 2011 06:07 PM
