not audio smart
Old Jun 4, 2014 | 11:02 PM
pretz's Avatar
pretz
Talking not audio smart
ok so I am looking at putting the following combo in my 2007 SG. thoughts from the smarter guys than me please. And I don't want to break the bank.
Polk Audio DB651 6.5-Inch Coaxial Speakers
Jensen - HD1BT
thanks much
Old Jun 5, 2014 | 06:10 AM
Gannicus's Avatar
Gannicus
Jensen - HD1BT
thanks much
Well that Jenson is on sale at Dennis Kirk for 399.00 which is a big hit right off the bat for an HU. My only suggestion would be to replace the DB's with Kickers on that set up.
The Kickers sound much better.
http://www.hifisoundconnection.com/K...FWNgMgodbyMALA
If you have any money left over this will make a major improvement on your set up:
http://www.sonicelectronix.com/item_...FaY-MgodRAcALA
Old Jun 5, 2014 | 07:20 AM
UltraNutZ's Avatar
UltraNutZ
Old Jun 5, 2014 | 09:30 AM
pretz's Avatar
pretz
thanks much for the advice
Old Jun 5, 2014 | 09:44 AM
0ldhippie's Avatar
0ldhippie
I really don't see the Jensen unit as an upgrade??? For under $400 ya could get a Biktronics install kit and kick a$$ head unit that I'm sure would blow the Jensen away??? Add some Infinity Kappas/Polk mm651s and rock on...
Old Jun 5, 2014 | 09:46 AM
UltraNutZ's Avatar
UltraNutZ
I agree. I was agreeing with Gannicus (should have pointed that out) about the kicker speakers...
that Jensen will appeal to a lot of people especially if they drop the price of it like I think they will
Old Jun 5, 2014 | 10:05 AM
pretz's Avatar
pretz
My biggest hurdle is wiring. I have absolutely zero knowledge with this process. So is there a wiring harness that plugs into the head unit and then into the HD? Yes I am clueless.
Old Jun 5, 2014 | 10:16 AM
UltraNutZ's Avatar
UltraNutZ
Call Bill @ Biketronics.. he'll hook you up with a head unit, the module to plug it directly into your existing stock wiring, excellent amps and speakers as well. There are also other vendors, J&M, Hogtunes, Hawg-Wired, etc. that sell plug and play stuff but the control module for your headunit, you should get from BT..
Old Jun 5, 2014 | 10:37 AM
pretz's Avatar
pretz
that will work for me. Thanx much my fellow forum riders.
Old Jun 6, 2014 | 01:33 PM
pretz's Avatar
pretz
Ok Nutz, I called Biketronics and spoke with John. After a great conversation I decided to pull the plug on the following. This setup will allow me to upgrade with an amp in the future. But for now it should be spot on. So needless to say I am looking forward to next week.
Sony MEX-M70BT
BT 1005X - 1998-2013 Multi-Brand Radio Install Kit
BT7P1 Speaker Upgrade
