I have a 2014 SGS. I put in the Boom Speakers shortly after buying it and am pleased but want louder and a little more Bass.
I've also got 12" apes so the stock mirrors are almost useless. I was wanting to get thoughts on using the mirror holes as a starting point for mounting tweeters from a Component Set.
I'd also like opinions on whether to go Coaxial or Component.
And pro's/con's of the Soundstream Nano vs the PBR vs the PPI Ion.
Unless something major happens I don't currently plan on moving the system beyond the batwing.
I don't know where you would run component tweeters on a '14 without the gage holes, unless you are going to drill big holes in your fairing. In that aspect, I would go with coax.
Positives on the Nano/PPI are cheap power. Negatives are you may lose FM reception.
Positives on the PBR is you will not need a remote turn on wire, great power, will not lose FM reception. Negatives is they cost a little more.
