Audio guru's
Old Jul 23, 2014 | 08:16 PM
Little Mike's Avatar
Little Mike
Default Audio guru's
Does anyone know if the Boom Audio 5 1/4" speakers are 2 ohm max or 2 ohm rms? Poured through the threads and can't seem to locate this answer. Harley feels the need to try and keep this info secret as if it's the cure for male pattern baldness.
Old Jul 23, 2014 | 08:28 PM
MURPHCC1's Avatar
MURPHCC1
from what I can remember, OHMS is a measure of resistance, RMS stands for ROOT MEAN SQUARE and it involves power only, it's .707 of PEAK power......2 ohms is 2 ohms.
Old Jul 23, 2014 | 08:40 PM
Gannicus's Avatar
Gannicus
lol Nice avatar Little Mike! The question is a little convoluted. 2ohm max???
Anyway they are 2 ohm speakers. RMS unknown. RMS is the root mean square and it would be a number like 50, 60, 75 or 100. My suggestion would be to forget you ever heard the name BOOM and move on. You want speakers with at least 100 watts RMS and 90+ sensitivity. look at JM and Infinity for your 2 ohm speakers. Look at Biketronics, Kicker and Pioneer D series for your 4 ohm speakers.
Old Jul 23, 2014 | 08:57 PM
Little Mike
I was asking because the 2011 RGC I just bought already has the Boom audio speakers in it. I can pick up a Clarion amp new for next to nothing. It says it's 2 ohm stable @ 2x75w max @ 2 ohm. After what I've spent on other upgrades in the past two weeks it's going to be a minute before I can get the $$ for a real system past the money warden. I'm just looking to find something to give the Boom's a little help until then. The interim will give me some time to research the setup I want to go with as a final upgrade. At that point I'm looking at the Biketronics and the new Fosgate bike set-up.
Old Jul 23, 2014 | 09:15 PM
AZ Rider's Avatar
AZ Rider
They would be 2 ohms regardless of their RMS or continuous rating as ohms is a measure of resistance.
So with that amp rating, it's probably about 35 watts rms into 2 channels and 75 watts peak power.
Old Jul 23, 2014 | 09:24 PM
Gannicus's Avatar
Gannicus
That amp might work if you keep the gains real low. I've seen so many BOOM speakers go KABOOM when guys put amps on em. . . I'm just a little gun shy when it comes to those speakers.
Old Jul 23, 2014 | 09:50 PM
Little Mike
According to the manufacturer specs it has a high/low pass switch to eliminate the real low base frequencies. I was thinking that would help with the overload..go kaboom..issue.
Old Jul 23, 2014 | 11:54 PM
Eshaw301's Avatar
Eshaw301
Don't do it! Cvo speakers are one ohm. To get a multichannel amp that is one ohm stable, you'll be don't spent a grip on it!
Tailwind
Audio Systems
92
Oct 3, 2017 02:42 PM
wevsspot
Audio Systems
Jan 22, 2016 09:48 PM
Nickblink
Audio Systems
Jul 15, 2014 03:41 PM
blockzilla
Mar 3, 2012 04:49 PM
Goon
Mar 9, 2011 07:14 AM
