Blown PBR
Brew61, I would run 2 of the Rockford 300/2's, if you MUST have FM !!
Stay away from the AB amps and those two questions go away. The Harley charging system does just fine with BR and Class D amps.
Buying from an authorized reseller is a very expensive insurance policy. Using Crutchfield as an example, prices are close to double for many items compared to other options.
If I only purchased one product in my entire life, the extra money might be worth it. However, if you look at risk vs. cost over many purchases, it usually makes more financial sense to pay less, especially if the savings are significant.
Example: If you buy 20 items at a 40% discount, over 8 of them would have to fail prematurely for that to be a bad choice. With normal failure rates for modern electronics below 5% (1 in 20), that's not likely to happen.
Not only that, but most manufacturer warranties don't cover other items damaged by theirs, or any reinstallation labor. So how about paying the authorized reseller double, but you're still out the speaker that got fried and all of the labor to swap the amp. None of that is covered. And you paid double.
Does it stink when something fails? Yes. But if you've been saving all along you can throw it away and you're still way ahead.
There are piles of exceptions, of course, like products with low discounts, high failure rates (e.g. Polk MM651 speakers), the cost of stress, etc. So sometimes it does make sense to pay more up front. But for a reliable amp like the pbr300x2, it doesn't seem to.
Just my 8 cents.
Explanation: Let's say the failure rate on new and/or factory refurbished items is about 5%. Over many years and many purchases, you buy 20 items at a 40% overall discount via unauthorized dealers or buying refurbished. To make that a bad financial decision, over 40% of the items (over 8 of them) would have to fail prematurely. Statistically at a 5% failure rate 1 will fail.
Now, normal failure rates for modern electronics are way below 5% putting the odds even more in your favor, but you get the point. Product research and seller feedback go a long way in minimizing the risks.
Just my 8 cents.
Good 8 cents! On the other hand looking at this thing from a customer service standpoint Rockford would be money ahead to replace the customers amp. They would stand to make more money providing good customer service than worrying about setting a precedent for returning amps. furthermore, if the reliability rate is 1 in 100 failures they are not looking at a major impact on their bottom line. Case and point: Biketronics is a much smaller company and their products have a LIFETIME warranty and everybody I know loves their customer service. Customer Service is the name of the game if you want to survive in todays marketplace.
Yes in this day and age I do still listen to FM. I don’t mind radio stations as they keep me informed on the ride to and from work. I also live in Canada and order a lot of stuff from the US and have a US shipping address so I am going across the border at least 2 to 3 times a month. Before I start heading down there on the way home from work I like to know what the border lines ups are so if they are long I will go another day. I do not own a cell phone and yes you read that right so I get my information from the traffic reports.
As for an A/B amp being hard on my charging system, didn’t know that, but on the other side my charging system has had a pretty easy life because every light on my bike is LED and I don’t have anything heated so the only draw on it is the stereo.
As for buying from an authorized dealer, I did just that, but what pisses me off is that RF says “oh they are only authorized to sell in there retail store and not online” give me a fricken break, you gave them permission to sell your product.
So ya it looks like I either spend $500 on an amp from Biketronics or JM’s or give another RF amp another try even though they have idiots running the company. I don’t think I will go with two amps but maybe just go with their 4 ch. Amp. When I had just the PBR300x2 I found that my front speakers over powered the rears so I would like the 4 ch so I can have the adjustment. I know you drop down to 75 watts with the PBR300X4 but now after playing with the PBR300X2 I have found out it has way more power than I would ever use. My HU volume goes up to 50 on the volume and when I am playing my MP3’s doing 120Kms it is blasting pretty loud just at 20. Guys riding way behind me say they can hear my stereo. If I turn it up to 25, I cannot even hear my bike running so I think 75 watts would still be plenty.
Just very surprised that RF is a vendor on here and they have chosen not to say anything.
Thanks everyone for their input.
Bruce
Class D means higher efficiency at let's say about 77%. That's 77% of usable power that's reaching your speakers and 23% wasted as heat. Now the class A/B on the other hand is let's say about 56% efficient; that means that 56% of the power is going to your speakers while 44% is wasted as heat. The extra current draw is the downside of the class A/B design. Hence is the reason why we should not be using class A/B amplifiers on our bikes with limited charging systems. Hope that helps brother.
Class D means higher efficiency at let's say about 77%. That's 77% of usable power that's reaching your speakers and 23% wasted as heat. Now the class A/B on the other hand is let's say is about 56% efficient; that means that 56% of the power is going to your speakers while 44% is wasted as heat. The extra current draw is the downside of the class A/B design. Hence is the reason why we should not be using class A/B amplifiers on our bikes with limited charging systems. Hope that helps brother.
Thanks Gannicus for your time.
I guess I will go with the PBR300X4 and order it from Sonic, I have bought lots from Sonic with no problems, they offer a One year Warranty so that should be good. They don't have any in stock right now so will have to wait.
Bruce
