Bt4180
Old Aug 19, 2014 | 07:52 AM
Gannicus's Avatar
Gannicus
Originally Posted by Moto Mike
BT uses 18 ga. wire in their speaker wire harness, so I guess that would be what they would recommend, seemed small to me. I didn't use their harness and wired my speakers with 16 ga. I don't think the difference between 18 ga. to 16 ga. will cause the terminals to fail. I did not have to "force" the 16 ga. wire into the terminals. Chunngle when you talk to BT ask them which ga. wire to use. I actually wish BT would use screw terminals on their amp.
I certainly hope not Mike. . . (cause the terminals to fail) I use 16 gauge wire for all my speakers. What gauge wire do they use for power and ground?
Old Aug 19, 2014 | 08:52 AM
Pioneer74's Avatar
Pioneer74
It looks like 12 gauge. The amp has all the wire you need already attached, including fuse holder.
Old Aug 19, 2014 | 10:26 AM
chunngle's Avatar
chunngle
Originally Posted by troop
I'm using 16 ga speaker wire and 10 ga power wiring.....
Thank you. Exactly what I was looking for. I will swap out the 8 ga. power for the 10 ga power this evening.
Old Aug 19, 2014 | 10:33 AM
Gannicus's Avatar
Gannicus
Thanks Pioneer!
Old Aug 19, 2014 | 01:18 PM
Kave Dweller's Avatar
Kave Dweller
Just checked my tracking number, my BT7.1's and my 2180 are sitting at my house, come on 4 o'clock. Seems like something that shouldn't take more than an hour or so should it? I'm fairly proficient in car stereos, never had the shark nose off though.
Old Aug 19, 2014 | 02:46 PM
Gannicus's Avatar
Gannicus
Lol. . . If you've never taken the fairing off it's going to take more than an hour.
Old Aug 19, 2014 | 03:15 PM
kryingame's Avatar
kryingame
Oh come on, the fairing is held by 4 bolts. It should take no more than 2 minutes to remove the fairing (along with the 3 screws holding in the shield). Probably the only challenging part is holding the fairing while disconnecting the headlight. (also reinstalling the fairing, the lower left bolt is always a P.I.T.A.
Old Aug 19, 2014 | 03:34 PM
Kave Dweller
I've had a batwing off a bunch of times, that one is easy, this is a road glide, which I have never done before.
Old Aug 19, 2014 | 03:39 PM
hd_rolling's Avatar
hd_rolling
Your thinking the batwing fairing like ours, the shark nose road glide fairing is a little more work to get off and a real pain to get back on.
Old Aug 19, 2014 | 05:47 PM
Gannicus's Avatar
Gannicus
Ditto!
