HU advice
Old Aug 21, 2014 | 07:19 PM
nemick's Avatar
nemick
Default HU advice
Does anyone know if an aftermarket HU is available that has a built in and accessible D/A converter. I like to listen to my music on my iPod Classic and want to run the digital signal from the main plug on the bottom of the iPod into a D/A converter instead of using the mini audio jack. The cheapest component on any iPod is the internal D/A converter. All the music on my iPod is at max resolution in ALAC.
Thanks
Old Aug 21, 2014 | 08:54 PM
kishstl's Avatar
kishstl
Agreed on the d/a converter on an ipod. However most internal DAC's on your typical head unit aren't a hell of a lot better. Iron cross audio has a cable that allows you to run your digital signal from your ipod directly into the stock head unit and maintain your handlebar functions. Obviously the stock HU DAC isn't great but better than your ipod and not too much different from your typical aftermarket head unit DAC. What speakers and amp are you running?
Old Aug 21, 2014 | 08:57 PM
nemick's Avatar
nemick
Just about to pull the trigger on BT 7.1's and RF BPR300x2
Old Aug 21, 2014 | 09:01 PM
kishstl's Avatar
kishstl
My set up exactly. I'm told that the BT 2180 would open up the 7.1s even more as they are 4ohm and power hungry. But I'll honestly tell you that after 2500 miles in 8 days I NEVER needed to push the amp hard to hear my music very clearly at almost any speed. And I'm running a stock HU.
Old Aug 21, 2014 | 09:44 PM
nemick's Avatar
nemick
That's great to know. I like the look of the Ironcross kit you mentioned. Thanks for that info.
Fathertime500
Audio Systems
Mar 18, 2016 12:55 PM
wils5150
Audio Systems
27
Dec 28, 2015 06:41 PM
Neil
Audio Systems
Jun 1, 2015 09:06 AM
kishstl
Audio Systems
Jul 24, 2014 11:02 AM
slammd
Audio Systems
Nov 18, 2013 07:35 PM
