Boom quick disconnect
Old Sep 13, 2014 | 04:03 PM
joes95bobber's Avatar
joes95bobber
Default Boom quick disconnect
I installed a Boom harness (see link) in my 2014 FLHXS. Drilled a hold on one of the side covers and surface mounted it. Great spot. The instructions tell you to mount it to the gas tank with double sided tape...yeah right, not a chance!
Problem is now the side cover cannot be removed completely. It dangles by the cord. I want to cut in a quick disconnect plug for proper removal. Does anyone have a source for something like this? Is it even a good idea to add a splice here? Its a communications device and I know CAT 5 cable (for instance) needs to be a home run with no splices......
http://www.harley-davidson.com/store...sic---comm-kit
Old Sep 13, 2014 | 04:32 PM
joes95bobber
I'll snap a pic....
Old Sep 13, 2014 | 04:47 PM
joes95bobber
Old Sep 13, 2014 | 05:29 PM
Pioneer74's Avatar
Pioneer74
I couldn't imagine it being down there. Seems like it would be uncomfortable when turning your head or leaning.
Anyway, you could cut the cable and put a Deutsch connector in it.
Old Sep 13, 2014 | 08:12 PM
joes95bobber
not at all. the headset I use has just the right amount of cord. so, if it is 6 wires, I select a 6 pin connector, right? there are both nickle and gold ones on ebay. which one is best? how do I select the wire size? anywhere from 14-22 awg available. Thanks for posting.
Old Sep 14, 2014 | 04:39 PM
joes95bobber
Old Sep 14, 2014 | 11:01 PM
bulkness's Avatar
bulkness
Have you thought about using a chrome tank console off an Ultra? We bought one and replaced the console on my wives Street Glide Special.
Old Sep 15, 2014 | 12:38 AM
Brew61's Avatar
Brew61
This is what you are looking for.
http://theelectricaldepot.com/index....ex&cPath=19_77
Bruce
Old Sep 15, 2014 | 07:09 AM
Pioneer74's Avatar
Pioneer74
I have the one from my Limited if the OP is interested in it.
I doubt it tho. The hole is drilled. No turning back now.
Old Sep 15, 2014 | 07:15 AM
Pioneer74's Avatar
Pioneer74
Bruce
You can buy those as a set on eBay pretty cheap.
