Dyno video of a 2009 Streetglide stock 96 in motor with drop in cams. Very nice to drive also very fast 150hp with 130 lbs tourque on pump gas. Custom turbo system built and tuned at DAS Performance. http://youtu.be/Ci1b5zrEThY
can you post the dyno sheet?
Nice set up some more tuning and clean up the afr's I see some more power there.
With Prochargers on a 96 inch with are 570 blower cam we achieve same numbers. We can get more but the bottom end wont handle it.
My own bike is a 2008 built 96 we did from the ground for Hot Bike and we made 182hp 151 tq.
What are using to tune that bike. With turbos we find Tmax with 2 bar works best....
Heres mine 08 Dragos built 96 inch procharger
Dragos stage3 heads
Dragos 570 blower cam
Dragos 80lbs injectors
Dragos Dragula 2 :1 pipe
AIM lock up
etc.,
Procharger
With cleaner afr at wide opens means better power.
Tuned with a PCV and TTS
Originally Posted by DAS HD
Here is the dyno run.
