Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Idles Differently
Old Jul 31, 2025 | 06:51 AM
Tcrafty's Avatar
Tcrafty
Originally Posted by JimL_15 Electra Glide
Keep what you have is the CV is a very reliable unit...
Agreed. Try the idle adjustment. If that doesn't fix the idle issue, then a good cleaning should do wonders. I'd definitely keep the carb you've got.
Old Jul 31, 2025 | 10:32 AM
John Harper's Avatar
John Harper
Rebuild the carburetor, it's time. Also, change the intake manifold seals, it's way past time. Then, you can do a proper idle adjustment. Anything else is just a bandage.
John
Old Jul 31, 2025 | 10:40 AM
TriGeezer's Avatar
TriGeezer
Regardless of whether it resolves the issue, a 22 year old carburetor is due for a rebuild. Get a factory service manual.
Old Jul 31, 2025 | 10:50 AM
Jake707's Avatar
Jake707
When you say adjust the idle, you are adjusting the idle speed right, not the idle mixture? No adjustments on a carb, with the exception of the idle speed, should be made unless the bike is hot/up to normal temp. A 15-20 mile ride should be enough. If it still wont idle after that, turn the idle speed up a bit to keep it running and set the idle mixture then re adjust the idle speed. Theres plenty of videos on youtube on how to do that. Altitude wouldnt be a factor here (not enough change) but temp/humidity could play a part of the idle mixture if different. It could also use a good cleaning too due to age. While Id normally recommend a Mikuni 42 if youre looking to change, tuning those can be overwhelming if you arent a wrench and in this case isnt "needed" so Id agree with others in staying with the CV for now, just check the diaphragm or rebuild altogether.
Old Aug 5, 2025 | 05:11 AM
Yankee Dog's Avatar
Yankee Dog
I'm with the guys who are saying pull the carb and give it a once over.
I also agree with changing the intake seals even if just on principle. They are old, can get brittle with time and leak air causing the symptom you describe. Just do a little reading first because there is a little positioning of the manifold and carb knowledge that is needed when replacing. Not a big deal, just something to be aware of. Toss the old manifold bolts and install new 12 point 5/16-18 x 3/4" bolts. Will make your life easier.
The carb really does not need a ton of parts. Watch some youtube videos on rebuilding and make notes. Keep it mostly stock for now. Of course clean it. All holes and passages are suspect. Especially if bike has sat with ethanol fuel for a while. Look for worn needle and worn needle seat, check specs like float height and inspect float needle. The accelerator pump diaphragm is a common replacement part but watch some videos and proceed with caution so you don't lose small parts. The needle jet is commonly installed upside down by mistake so take some pics. Also the idle mix screw has a really small rubber O-ring that often stays stuck in the bore. It is in there and you need to fish it out.
Point is, give it a once over. It is due and can't hurt. Just takes a little time. Do you have a repair manual for this bike? If not, get one. A aftermarket manual download is better than nothing but the factory manual is hard to beat.
Old Aug 5, 2025 | 09:56 AM
clintdowns's Avatar
clintdowns
6th Gear
where can I get a factory manual?
Old Aug 5, 2025 | 10:47 AM
t150vej's Avatar
t150vej
A Factory Service Manual will not help you with any carburetor issues other than setting the float height.
Old Aug 7, 2025 | 09:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Remove carburetor, disassemble and clean.
Clean petcock screen.
Replace fuel hoses.
Replace intake seals.
This should be done every 22 years.
Old Aug 7, 2025 | 06:27 PM
John Harper
If the carb has not been opened, a JIS #2 screwdriver or bit is a nice little add to your toolbox.
John
torquey1
Carburetor Related
Jan 28, 2024 09:21 AM
Mikedee
Oct 22, 2017 12:21 PM
Junker
Engine Mechanical Topics
Jun 27, 2014 07:37 PM
tcs59
Sep 10, 2008 06:33 PM
ChiTownDaddy
Mar 30, 2006 07:00 PM
