Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
thunderslide help: good perf, poor mpg
Old May 1, 2011 | 08:58 AM
texasridr's Avatar
texasridr
Default thunderslide help: good perf, poor mpg
I had an Indy dyno tune my stock 98 Evo with high flow a/c and KhomeWerks mufflers. The carb already had the Thunderslide, and so I assumed it has a DynoJet kit installed as well. Mechanic said it was not, and wasn't familiar with the emulsion tube it had, and that his jets would fit it, so he ordered a DynoJet kit. Because I didn't want MPG to suffer, I had requested that he stick with a 42 and 160 main, but this was when I dropped it off, not after he started the tune.
So after the tune, it runs great, but my MPG is worse. I used to get in the low 40's, which I was not pleased with, now i'm at 37 at very best with easy riding conditions. He said it's really set up on the lean side, per my instructions, but my mpg stinks.
So my question is, does the Thunderslide itself cause poor mpg's? Why? Should I remove it and find a stock slide and other parts? ... OR, How do I make the DynoJet kit with Thunderslide work properly without killing my mpgs? I may have to do it myself because the Indy says 35mpg is "normal" when you dyno tune it for performance. I don't know if he'll "fix" it without wanting more money. $250.00 for the tune plus $90.00 for the kit, makes me a non-happy customer.
I'm a conservative rider and prefer to get long range from my gas tank. I want a smooth ride, not necessarily a fast one.
Old May 2, 2011 | 09:22 AM
ajayrk's Avatar
ajayrk
Dyno jet kit = poor gas mileage. Better to tune with stock parts, a raised needle or a 1989 Sportster needle.
You can adjust what you have. Lower the needle one notch to lean out the mid range.
Old Jan 14, 2012 | 03:06 PM
xanadu's Avatar
xanadu
Stage IV
you will get responses all over the map with this as I have. I listened to a lot of them and nothing worked. so many people told me the dynojet thunderslide kit was garbage and killed gas mileage, but my stock configuation was not much better if at all. and the thunderslide did give a lot better throttle response with that lighter spring and lighter slide. if you find an answer let me know. xanadu at wydebeam dot com.
Old Jan 15, 2012 | 11:21 AM
grbrown's Avatar
grbrown
It sounds as if your dyno guy replaced the Thunderjet with the Dynajet. You can have one or the other, not both! They are designed to undo the lean burn setup of a stock carb, give better air/fuel ratios, better performance and, if you use it well, greater fuel consumption. In essence that will happen with any similar changes.
If you go back to a stock setup with jetting, you will lose performance, but probably gain improved fuel consumption.
Spanners39
EVO
23
Dec 23, 2014 08:24 PM
texasridr
EVO
21
Nov 17, 2013 09:16 AM
roadkingharry
Carburetor Related
Feb 4, 2012 10:56 AM
mantodou
Exhaust System Topics
11
Sep 30, 2007 09:13 AM
ButtMan1000
Dec 30, 2006 08:59 PM
