Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
New needle
Old May 6, 2011 | 08:56 AM
Smokin 03's Avatar
Smokin 03
Default New needle
I just installed a new needle in my carb, I went with the the Sporty needle, I am just wondering if anyone can tell me how to determine the spacers needed.
I installed the new needle with the spacer that came out with the old needle, which is about 1/16 " the needles were just about the same length with that spacer but the new one was still longer
Old May 6, 2011 | 09:01 AM
roadkingharry's Avatar
roadkingharry
If you mean washers when you say spacers, the sporty needle doesn't need any washers or spacers. The washers are used with a stock needle to raise it up and enrichen the mixture.
Old May 6, 2011 | 12:42 PM
Smokin 03's Avatar
Smokin 03
Thumbs up
I guess I mean washers. I am going to try it like it is See if all goes well.
Thanks for the Info.
Old May 7, 2011 | 05:47 AM
roadkingharry
Search Joe Minton Carb Setup on google. I have some good sites bookmarked on my other laptop but I spilled coffee on it and the f-er won't boot up otherwise I would give you some links.
Old Jul 7, 2012 | 05:37 PM
Deuce03's Avatar
Deuce03
2nd Gear
Will the Minton carb setup work on a Keihin 44mm carb or just for the stock 40mm?
Old Jul 8, 2012 | 03:52 PM
kansasroadking's Avatar
kansasroadking
that is just for the 40, not the 44; it uses different needles
Zenmoto
Carburetor Related
Feb 11, 2017 08:18 AM
vintagebikes
Aug 6, 2013 11:48 AM
jasvncnt
Jul 15, 2009 09:49 AM
TurboExempt
Aug 6, 2008 07:53 PM
nsodpty52
Oct 1, 2006 05:58 AM
