Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Carb adjustment
Old Apr 5, 2014 | 03:42 AM
Banditsghost's Avatar
Banditsghost
Default Carb adjustment
Okay y'all, I am currently working on a 01 Fatboy, basically stock for a friend. Problem is bike is real lazy when you twist the throttle, under load or sitting. When you snap the throttle there isn't a lot of response, it tries to bog out. Now from my experiences, racing cars and auto mech, this should be a air fuel problem and a simple fix, but on the stock carb I have no idea where the dang adjustment screw is. Did HD hide it and I am not seeing it or is it behind a factory plug? Am I missing something.
Thanks
Old Apr 5, 2014 | 06:02 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Remove the air filter and check to see that the accelerator pump squirts gas into the throat when you twist the throttle. Keep a safe distance the first time you give it a twist just to be safe...
Also check for an intake leak.
It never hurts to disassemble the carb and clean it.
Old Apr 7, 2014 | 12:18 AM
Banditsghost
Ok, I'll check that.
Old Apr 7, 2014 | 07:14 AM
nhrider1's Avatar
nhrider1
Thanks
Idle air adj. screw is located on the bottom of the carb behind the float bowl. It's capped on stock bikes, but easily removable with a drill and a sheet metal screw. It only affects from idle to about 1/8 throttle.
Sounds like you have a midrange problem. Yes... check the accelerator pump, but you will probably need to rejet and change or raise the needle.
Old Apr 8, 2014 | 01:15 AM
Banditsghost
Thanks, I will look into that. My bet it was never re jetted after the bigger pipe and air cleaner were installed. While I got it apart to do that I'll get that plug removed from the bottom of the float bowl too.
Old Apr 9, 2014 | 06:19 PM
gambler85gw's Avatar
gambler85gw
Default Timing
Check timing
Old Apr 10, 2014 | 09:53 AM
46u's Avatar
46u
Did he change anything just before this problem? How does it idle? Check for manifold leaks as well.
JohnnyC
EVO
42
Jul 14, 2016 09:23 AM
diddlyd
Carburetor Related
Dec 19, 2015 11:17 PM
langwilliams
EVO
Aug 29, 2012 06:29 PM
hog85
EVO
18
Aug 26, 2011 08:09 AM
Neil
Jun 29, 2011 12:40 AM
