Classic All 'historic' bikes.
Shovel cams and valves
Old Apr 10, 2008 | 09:57 PM
1979fxs's Avatar
1979fxs
4th Gear
Default Shovel cams and valves
I am looking for suggestions on cams.
Here is a break down of what will be run.
74" .020 over KB's
dual plug heads
dual Dyna coils
Dyna digital programmable ignition
S&S Super E carb
4 speed tranny
I am also looking for information on valves. I measured mine pretty closly and the exhaust is about 1.75" and intake is 1.93" are these stock? I am looking for a well rounded cam that will give decent mid and top end performance.
It looks like Andrews are reasonably priced and the A or J grinds seams like the options that would suit my needs.
Thank you,
Tom
Old Apr 23, 2008 | 01:46 PM
Bouncer's Avatar
Bouncer
3rd Gear
Default RE: Shovel cams and valves
I would run the Manley street stock stainless steel valve set. There is a package deal that comes with the springs, collars, and keepers. I would also replace the valve guides with Ampco 45's and k line valve seals.I would also run solid lifters and Andrews pushrods to really wake this motor up. With this setup, you will have a solid, long lasting top end.
The Andrews A grind would be a great choice.
The only thing I would do different is run wisco pistons. Only because they offer a higher compression verison, but it will run very well on your choice of piston also.
Hope this helps you out.
Plated & Screwed
Engine Mechanical Topics
Jan 29, 2017 12:53 PM
hutch08
16
May 20, 2014 12:33 AM
user 46092
Exhaust System Topics
11
Sep 19, 2011 12:45 PM
cryan9
Jun 12, 2010 12:47 AM
Fatboy931
EVO
Jul 23, 2007 10:29 AM
