Thud, ya gotta be really careful putting on a set of raked trees on a stock frame. Very easy to end up with too little trail, or even in a negative trail situation. I always run the numbers to make sure the trail stays in the 4 - 6 inch range. Seldom recommend a set of raked trees, except to correct for too much trail after raking a frame.
Thanks pococj. Honestly I have never used raked triple trees but know those who have and like them. What you say makes sense for sure, for non-springers especially. Is there a link for info on the calculations you use? I have seen them somewhere but can't remember where.
If I add 3 deg or Triple Tree Rake, my trail drops to 7.06
The bottom of my frame is not level, the front of the bottom tubes are about 2 inches higher
than the back. Adding the tripple tree rake would help flatten that out too eh?
My old Kawasaki chop had 34 degrees in the frame, and i put 7 degree trees on it. Can't remember what the trail was, but it rode GREAT!!! Looked good with 41 degrees total! Not much for turning radius though.....[]
I think the 80 FLT had a 5 speed.
The FLH was made until 84 (4 speeds).
3 degree trees (from a FX) and 4" tubes would work just fine, this look good with a 16" wheel as well as a 21" (the 21 will rase the front a little), this will give you a tril of 4" to 5", just right.
There is still a lot of stuff that you can get for the old 4 speed bikes. Just be awhare of quality, some supplers sell "cheep junk" (not the price, the quality).
Best of luck
8-UP
9 inches is past what is considered optimum for low speed handling, but it'll track like a locomotive on straight rails! Adding some rake in the trees would bring you closer to level and reduce the trail some, as you pointed out. 7 inches is still past optimum, but not too bad.
