Performance Machine 3-button housing
Old Nov 12, 2020 | 08:44 PM
ARNAV's Avatar
ARNAV
Default Performance Machine 3-button housing
Hello, while trying to remove the housing, I released the two Allen bolts shown in the upper left corner of the picture but it still won't move. Does anyone have experience with the type of housing? are there more bolts hiding in the other little holes marked "???"
It looks like something is still unopened because this thing doesn't spin or move.
Thanks.
Old Nov 13, 2020 | 11:03 PM
megawatt's Avatar
megawatt
Does Performance Machine have instructions on their website?
Maybe you can call them for info.
Old Nov 13, 2020 | 11:06 PM
TwiZted Biker's Avatar
TwiZted Biker
What's with the set screws in the upper left of that picture ?
Anything on the bottom of it recessed out of sight?
Old Nov 14, 2020 | 08:52 PM
ARNAV's Avatar
ARNAV
I contacted performance machine, they replied that the two upper Allen bolts (in the top left corner) are the only thing that is holding it.
I released them but it still won’t move..
I will try again, still have no idea why it won’t move...
Old Nov 14, 2020 | 09:19 PM
TwiZted Biker
Set screws you sometimes have back way out to work, good luck on this.
Back them out then tap the housing gently with a rubber hammer or the wood handle of one, see if it's just stuck.
Old Nov 14, 2020 | 10:18 PM
ARNAV's Avatar
ARNAV
Will do. Thank you!
Old Nov 15, 2020 | 05:04 PM
joe40x's Avatar
joe40x
Assuming this is the right side...
1) loosen the master cylinder screws...No, not the lid. The screws that hold it onto the handlebars.
2) Loosen the set screws that hold the grips on.
The switch housing should be loose by now. The only thing currently holding it there is it being "pinched" between the MC and grip.
JensBobber
General Topics/Tech Tips
38
Feb 28, 2019 05:46 AM
OldWheels
EVO
May 16, 2016 10:39 AM
Oh Four Z
Classic
May 25, 2014 09:52 PM
Peso Joe
Feb 7, 2010 01:59 PM
vegashd
Mar 26, 2007 10:47 PM
