panshovel?
Old Feb 23, 2021 | 11:57 PM
62 Pan Shovel's Avatar
62 Pan Shovel
No such thing as an original Pan Shovel engine, all pan shovels are back yard models. Pan Heads which were converted to shovel tops, that is what a Pan Shovel is. The early shovels were merely shovels, nothing to do with pans, bottom or otherwise.
Old Feb 24, 2021 | 05:48 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Generator Shovelheads were the last of the original Harley-Davidson's before AMF purchased them.
1966-1969, being the shortest production run of any Big Twin produced.
I have a 1967 FLH, which was the last year of the "hand booster" aka mousetrap clutch, last year of the cast iron oil pump, tombstone speedo face, and left side drum f/brake.
1963-1967 only s/bag rails, and mine was purchased with a center stand also.
Rolled off 14k trouble-free miles in one season years ago.
Scott
Old Feb 25, 2021 | 04:09 AM
62 Pan Shovel
You are completely off the thread, this post is about Pan Shovels, a Pan Shovel is a pan head which has had the later shovel tops introduced, nothing whatsoever to do with generator shovels. Only a pan head can be a Pan Shovel, pan heads are from 1948 to 65 which is the range of dates possible for a Pan Shovel.
Old Feb 25, 2021 | 05:55 AM
Hillsidecycle.com
Sponsor
On thing is for sure, a set of Shovelheads on a Panhead engine, certainly helps the power vs the mouse-maize port the air stream is subjected to from a Panhead.
Incredibly poor design.
Scott
Old Feb 25, 2021 | 06:22 AM
Hey Man's Avatar
Hey Man
1966 was the year of what's been nic-named as the "Pan Shovel." Introduction of the Shovel top end on a Pan bottom end. As far as what year yours is I guess you could check the VIN on the engine case. They used generator cases up until 1969 and bikes were titled to the engine because frames had no numbers until 1970 at which time the bikes were titled by the frame numbers. To confuse matters more I think there were a couple of years where the frame and engine numbers didn't match. That caused a few problems. 1970 was also the first year of the cone motors- no more generators. G'luck .
Old Feb 25, 2021 | 06:30 AM
Uncle Larry's Avatar
Uncle Larry
Flat side shovels was often heard around here ;>)
Old Feb 25, 2021 | 06:42 AM
62 Pan Shovel
Rubbish, utter nonsense, read my post above, the early shovels were merely that, shovels. Nothing to do with Pan Shovels, only a Pan can be a Pan Shovel
Old Feb 25, 2021 | 08:28 AM
Uncle Larry
Easy big guy ... It's all good and some days it's real good
Old Feb 27, 2021 | 07:05 AM
Hey Man's Avatar
Hey Man
Yup, in a world where what we need are
all I'm feeling are more
Old Feb 27, 2021 | 05:11 PM
98hotrodfatboy's Avatar
98hotrodfatboy
A true shoevel was a cone shovel, although they did combine the Flat side cases in the early years with the Shovel heads... I believe they were salvaging old to new..
Cory81
May 28, 2014 07:50 PM
glennrightsell
Motorcycles For Sale
Mar 21, 2014 06:54 AM
HB
May 24, 2012 05:58 AM
framda
Jan 19, 2011 08:18 AM
CTP
Ironhead
26
Jun 14, 2008 08:12 PM
