New frame registration
I was initially going to cut the factory frame & use a weld on hardtail, but I also want to increase the rake for a longer front end. That got me to thinking that it would be simpler/cheaper to just buy a 200 XL 40⁰ frame & save myself a bunch of work & headscratching (and having to build a jig)
The frame comes with a 'certificate of origin' & I'm not sure what's involved with getting a title & registration with that. However, the bike I bought has a clean title....
Can I re-stamp the VIN onto the new frame, use the existing title & scrap the old frame? That's what we used to do back in England, years ago.
This will be the first full custom I've built since I moved to the US I've never had to deal with this before.
For your own use, just cutting out the Vin portion of the legal frame and grafting that section into the custom frame. It’s probably quasi legal, probably no issues until you sell it or something.
is there any exemptions for older stuff? My current state Wisconsin has special plates for collector vehicles and Hot Rod type vehicles
To title it, the state police had to come over & inspect it before anything else, which meant I had to temporarily rig up a few parts I wasn't planning on actually using, like turn signals & a horn. I also shoved some old baffles in the 2" drag pipes so they wouldn't give me any **** about that either. The cop came over & looked at it, had me start it & then examined all my paperwork. I believe after that he proceeded to "stamp" my frames neck area with my new VIN, which starts with "SOS" (for Secretary of State). He did a sloppy job & screwed up a little area of the powder coated frame, but I had a title in about 3 weeks. It may be different now, I dunno. Point is, I didn't have an HD VIN because I never had an original frame with a VIN to start with, so you may need to consider that if you buy a frame.
Now in 2007, I was hit by a cager on a Softail I had and it required a new, HD frame. Harley would stamp my existing VIN into that new frame before sending it to me, but NOT before we cut the old VIN off & sent it to them. This ensures that the VIN is not on 2 bikes at once. I still have that old Softail frame laying around with a section removed up near the neck.
If I was you & really wanted to retain a Harley VIN, I would mod the existing frame. If you're building something really wild & just can't use it then be prepared to possibly NOT have an HD VIN, but each state may be different.
Good luck.
Lights and all that will have to meet current regulations. Depending on how picky they get require reflectors may need to be in place.
Good luck with your project. Post pictures of the project.
