I have a small problem I got my first harley and first found out it does not have a harley frame it is an ultracycles softail frame 03 model at least that's what the title says first question the only numbers I can find on the entire engine is z189 just left of the external oil pump and again on the other half right across from the one next to the oil pump so z189 is not a harley motor tube next numbers I found were on the 5 speed trans 5835300047 the frame vin starts with ult6891 then there are 2 letters and the 8 more numbers and it was made by ultra cycles already verified that but that's it and the motor leaks oil bad so I need a gasket set but I don't know for what size and all that other stuff please I need help so I can stop this leak and enjoy my bike but it leaks oil faster than it uses gas I do know it's an evo but that's all I know
Sad to tell you that you do not have your first "Harley" yet. You have some sort of custom manufactured motorcycle put together by a company to look like a Harley.
Probably should do some research and find out who made the motor.
Can't help you as it is not a Harley motor so any Harley parts listing would be a shot in the dark and probably not work.
After the fact but you should have looked at the title and other documents before purchasing.
