Battery will not charge
Old Feb 14, 2008 | 11:40 AM
vanbanks's Avatar
vanbanks
1st Gear
Default Battery will not charge
I built an aftermarketmotorcyclewith a 100in motor and a 32 amp charging system. The bike has about 200 miles on it, it's on the third voltage regulator, the second battery and it still will not get 14 volts at the battery on engine RPM'sabove idle. The stator puts out anywhere from 60 to 90 amps above idle, the regulator has a good ground, the battery cables are as new as the bike.The stator isn't grounded or open. The battery is at full charge. Help!!!!
Old Feb 15, 2008 | 08:48 PM
miacycles's Avatar
miacycles
Default RE: Battery will not charge
Make sure the stator, rotor and regulator are all for a 32 amp system.
Old Feb 18, 2008 | 09:38 AM
dog155's Avatar
dog155
Have you done the turn on all the electrical load and see if it charges thing?
Old Feb 19, 2008 | 09:48 AM
sqdealgeorge's Avatar
sqdealgeorge
Is that stator output 60 to 90 volts AC ? at about 2000 rpm
highenergy
Jan 3, 2015 09:45 PM
rodney123456
Jun 15, 2011 07:27 PM
hucks 08
May 26, 2010 07:23 PM
sporty79
Oct 20, 2009 10:22 AM
tmatador
Feb 13, 2009 08:26 AM
