Charging system double check
I'm pretty sure I did everything correctly, but a second set of eyes never hurt.
Anyway, my after charging the battery overnight, it's holding a charge of 12.7V. With the engine idling the battery checks at about 13.8V.
Checking the voltage at the regulator plug shows 11.xV at each terminal.
Checking the resistance across each pin of the stator shows 0.7 - 0.8 Ohms
The resistance between each pin from the stator to the frame ground shows infinite resistance.
The output at idle of the stator is about 20 VAC. Revving the engine causes an increase in voltage, as it should.
So, according to the instructions, I should have a bad regulator. Since I have an 06, I was suspecting it would be the rotor bolts, so maybe this is the silver lining.
My question is, am I reading everything in the instructions correctly? I must have read through them 4 times, but sometimes you miss something and everything else gets taken out of context. Any help is appreciated.
"after charging the battery overnight, it's holding a charge of 12.7V. With the engine idling the battery checks at about 13.8V".
"The output at idle of the stator is about 20 VAC. Revving the engine causes an increase in voltage, as it should"
So what are the symptoms?.
According to step 2, the voltage at the regulator end of the regulator/stator connection should be 0. I'm getting 11.xV at each pin. This, along with the fact that my brand new battery took a dump after only a few short rides, leads me to believe the charging system, specifically the regulator, is at fault. Even though the voltage at the battery reads 13.8 at idle. I just want to make sure I'm reading the instructions correctly.
Try the voltage regulator. Might be the problem. Check the voltage coming in to the battery at idle a few times after you replace the regulator. I was getting 13.7-13.8 @ idle right after I replaced the voltage regulator, but, within a couple of days, I was back to getting the same reading at idle or off.
Your service manual probably references an electrical repair manual for your bike. Mine cost $60 from the dealer, but it's well worth it.
